Hello…in my case while examining this situation I remembered that in the first surrounding (whole network) proxy server is being used. Since i don’t have constant access to that surrounding I can not test if everything would work fine if I have used the option for proxy server in the test. Can this be the source of the problem? You might say I should test it and then report back again, but I want to be ready when I go there next time, so I’m just wondering is there anything I posted here that might indicate where the problem is?
