Hi
I’m in the process of writing some code for the W5500. Currently, I’m facing the issue that as soon as I start to set the MSS the chip stops to respond to ICMP. Is this normal?
My code:
void w5500_read_data(uint16_t offset, uint8_t block, unsigned char *data_out, int length) {
unsigned char *buffer = malloc(3 + length);
buffer[0] = offset >> 8;
buffer[1] = offset & 0xFF;
buffer[2] = (block&0xF8) << 3;
SpiOpenPort(0);
SpiWriteAndRead(0, buffer, buffer, 3 + length, 0);
SpiClosePort(0);
memcpy(data_out, buffer + 3, length);
void w5500_write_data(uint16_t offset, uint8_t block, unsigned char *data, int length) {
buffer[2] |= 0x04;
memcpy(buffer + 3, data, length);
SpiOpenPort(0);
SpiClosePort(0);
void w5500_init(void) {
unsigned char buffer0[1];
// SW Reset
buffer0[0] = 0x80;
w5500_write_data(0x0000, 0x00, buffer0, 1);
usleep(100 * 1000);
w5500_read_data(0x0039, 0x00, buffer0, 1);
if(buffer0[0] == 0x04) {
printf("Detected Chip W5500! \n");
} else {
exit(1);
void w5500_configure_ip(void) {
unsigned char buffer0[6];
// Write Gateway IP Address Register
buffer0[0] = 172;
buffer0[1] = 16;
buffer0[2] = 90;
buffer0[3] = 1;
w5500_write_data(0x0001, 0x00, buffer0, 4);
// Write Subnet Mask Register
buffer0[0] = 255;
buffer0[1] = 255;
buffer0[2] = 255;
buffer0[3] = 0;
w5500_write_data(0x0005, 0x00, buffer0, 4);
// Write Source Hardware Address Register
buffer0[0] = 0x00;
buffer0[1] = 0xAA;
buffer0[2] = 0xBB;
buffer0[3] = 0xCC;
buffer0[4] = 0xDE;
buffer0[5] = 0x02;
w5500_write_data(0x0009, 0x00, buffer0, 6);
// Write Source IP Address Register
buffer0[0] = 172;
buffer0[1] = 16;
buffer0[2] = 90;
buffer0[3] = 150;
w5500_write_data(0x000f, 0x00, buffer0, 4);
void w5500_configure_socket(void) {
unsigned char buffer0[2];
// Write Socket n Maximum Segment Size Register - 1460
buffer0[0] = 0x05;
buffer0[1] = 0xB4;
w5500_write_data(0x0012, 0x01, buffer0, 2);
// Write Socket n Source Port - 5000
buffer0[0] = 0x13;
buffer0[1] = 0x88;
w5500_write_data(0x0004, 0x01, buffer0, 2);
void w5500_connect_socket(void) {
int main(void) {
w5500_init();
w5500_configure_ip();
w5500_configure_socket();
//w5500_connect_socket();
