there is a telnet daemon enabled on the WizFi630 module. Is it possible to configure the module from within a telnet session?
The latest firmware version available for download from wiznet.co.kr is 1.1.25. Now, the modules I received from a distributor are already running version 1.1.28. So what is the current firmware version and where am I supposed to download them from?
What do you mean 1.1.28 is not an official firmware? It is installed on some of the modules we’ve received from an official WIZnet distributor.
On status_content.asp it is listed as “DS620P-4M-usb-sta-1T1R_v1.1.28-2013/04/09, 10:53:05”. The modules we’ve received with 1.1.25 display “DS620P-11n-4M-usb-sta-PCIe_v1.1.25-2012/07/26, 03:24:45” on this page.
I’ll be happy to provide the mac addresses of the affected modules if it helps WIZnet clarify this situation.
It means that WIzfi630 are mass-produced in WIZnet’s factory with <1.1.25>. (not <1.1.28>)
So, if you want WizFi630 <1.1.28> in much quantity, I think that you had better discuss with the distributor.
In other words, when you order WizFi630, you should specify the f/w version(you need).
