Hi, I looking at putting a W5500 on my board with a S32K148 main processor. I need to send data over Ethernet at 10Hz (only send, no receive). Is this implementable?
Has anyone used a wiznet with that chip family?
Thanks for the help!
Or is there a SPI routine I could send to just transmit data without the library?
Hello
I’ll share the WIZnet iolibrary with you. Please refer to it.
Hi Louis
I can’t link the library to my code unfortunately as I use a library block that just transmits the bytes I select over SPI when triggered.
Is there by any chance a simplified list of commands that I can send to get my W5500 chip to transmit test data just so I can check that the hardware design is correct?
Thank you very much!
