Hello everyone,
I am able to connect my laptop to w5500 without any router but when I am connecting it to the office local network then it is not getting IP.
Here is my code.
void eth_reset()
unsigned char status_ir;
GPIOB-> BRR |= (1<<7); // Reset pin
HAL_Delay(200);//reset
GPIOB-> BSRR |= (1<<7);
HAL_Delay(500);
reg_wizchip_cs_cbfunc(cs_sel, cs_desel); // cs select and deselect pass in wizchip library
reg_wizchip_spi_cbfunc(spi_rb, spi_wb); // receive buff and transmit buff pass in wizchip libra
//wizchip_init(socketRxTxBuff, socketRxTxBuff); // Socket Rx amd Tx buffer initialization (Max 16kb for rx and 16kb for tx), Max size can be divide in 8 socket buffer according to need
if(ctlwizchip(CW_INIT_WIZCHIP,(void*)memsize) == -1){
UARTSendString(logPort, (unsigned char*)"WIZCHIP Initialized fail.\r\n");
//while(1);
volatile wiz_PhyConf phyConf =
PHY_CONFBY_HW, // PHY_CONFBY_SW
PHY_MODE_AUTONEGO, // PHY_MODE_AUTONEGO
PHY_SPEED_100, // PHY_SPEED_100
PHY_DUPLEX_FULL, // PHY_DUPLEX_HALF
volatile wiz_NetInfo netInfo = { .mac = {0xa1,0xb2,0xc3,0xd1,0xe1,0xf4}, // Mac address
.ip = {192,168,1,199}, // IP address
.sn = {255,255,255,0}, // Subnet mask
.gw = {192,168,1,1}, // Gateway address
.dns = {0,0,0,0},
.dhcp = NETINFO_STATIC};
//wizchip_setnetinfo(&netInfo);
HAL_Delay(200);
ctlnetwork(CN_SET_NETINFO, (void*) &netInfo);
//UARTSendString(2, "ctlnetwork\r\n");
HAL_Delay(200);
ctlwizchip(CW_SET_PHYCONF, (void*) &phyConf);
//UARTSendString(2, "ctlwizchip\r\n");
HAL_Delay(200);
ctlwizchip(CW_GET_PHYLINK, (void*) &tmp);
// setSIMR(0x01);
Please suggest any change if I am doing anything wrong.
