Hi Team,
We are using WizFi 360 WiFi module with firmware version 1.0.7.5.
We are able to communicate to WizFi module at 1000000 Baud, when HW Flow control enabled.
Now, we have updated the WizFi firmware to latest i.e 1.1.2.0
UART settings are : 1000000 Baud and HW Flow control enabled => with this configuration, WizFi module is not responding with corresponding response
14:55:38.909 → ready
14:55:39.629 → ATE0
See above log, there is no response (OK) coming from WizFi Module for Echo control command.
And if use 115200 instead of 1000000 and HW Flow control enabled, there are no issues with WizFi response.
WiFi Module Version => 1.0.7.5, Uart Settings => any supported Baud and HW Flow Control Enabled, WiFi module is giving responses properly
WiFi Module Version => 1.1.2.0, Uart Settings => 115200 Baud and HW Flow Control Enabled, WiFi module is giving responses properly
WiFi Module Version => 1.1.2.0, Uart Settings => Greater than 115200 Baud and HW Flow Control Enabled, WiFi module is not giving response
Please help us in identifying the problem.
