Hi.
I want to transfer data by connecting the W5500 module to the STM32H7 board. I wanted to test it before starting my project. My test code is as follows. My code gets stuck and does not progress in the socket() function. As suggested, i tried to read the PHYCFGR register. i obtained the value of 255 from this register. And when i attempted to set the IP address and other settings at line 80 (You can check my code below, i numbered them), and tried to get all the parameters set in the W5500 at line 83, all the parameters returned with a value of 255. What could be the problem? I believe i have made the GPIO connections correctly. I used SPI5. What should i do?
/* USER CODE BEGIN Header */
/* USER CODE END Header /
/ Includes ------------------------------------------------------------------*/
#include “main.h”
/* Private includes ----------------------------------------------------------/
/ USER CODE BEGIN Includes */
#include “socket.h”
#include “wizchip_conf.h”
#include <string.h>
#include “loopback/loopback.h”
/* USER CODE END Includes */
/* Private typedef -----------------------------------------------------------/
/ USER CODE BEGIN PTD /
int sn = 0;
#define mydata “test\n”
int i = 0;
uint8_t bufSizeTx={2,2,2,2};
uint8_t bufSizeRx={2,2,2,2};
/ USER CODE END PTD */
/* Private define ------------------------------------------------------------/
/ USER CODE BEGIN PD */
/* USER CODE END PD */
/* Private macro -------------------------------------------------------------/
/ USER CODE BEGIN PM */
/* USER CODE END PM */
/* Private variables ---------------------------------------------------------*/
SPI_HandleTypeDef hspi1;
SPI_HandleTypeDef hspi5;
/* USER CODE BEGIN PV */
/* USER CODE END PV */
/* Private function prototypes -----------------------------------------------/
void SystemClock_Config(void);
static void MX_GPIO_Init(void);
static void MX_SPI1_Init(void);
static void MX_SPI5_Init(void);
/ USER CODE BEGIN PFP */
/* USER CODE END PFP */
/* Private user code ---------------------------------------------------------/
/ USER CODE BEGIN 0 */
void W5500_Select(void) {
HAL_GPIO_WritePin(W5500_CS_EX_GPIO_Port, W5500_CS_EX_Pin, GPIO_PIN_RESET);
- void W5500_Unselect(void) {
- HAL_GPIO_WritePin(W5500_CS_EX_GPIO_Port, W5500_CS_EX_Pin, GPIO_PIN_SET);
- uint8_t spi_rb(void){
- uint8_t cdata;
- HAL_SPI_Receive(&hspi5, &cdata, sizeof(cdata), 100);
- return cdata;
- void spi_wb(uint8_t b){
- HAL_SPI_Transmit(&hspi5, &b, sizeof(b), 100);
enum Status
Failed = 0,
Success = 1
uint8_t validSetNetInfoResult(wiz_NetInfo* _set, wiz_NetInfo* _get)
return(!memcmp(_set, _get, sizeof(wiz_NetInfo)));
/* USER CODE END 0 */
- @brief The application entry point.
- @retval int
int main(void)
/ USER CODE BEGIN 1 */
/* USER CODE END 1 */
/* MCU Configuration--------------------------------------------------------*/
/* Reset of all peripherals, Initializes the Flash interface and the Systick. */
HAL_Init();
/* USER CODE BEGIN Init */
/* USER CODE END Init */
/* Configure the system clock */
SystemClock_Config();
/* USER CODE BEGIN SysInit */
/* USER CODE END SysInit */
/* Initialize all configured peripherals /
MX_GPIO_Init();
//MX_SPI1_Init();
MX_SPI5_Init();
/ USER CODE BEGIN 2 */
reg_wizchip_cs_cbfunc(W5500_Select,W5500_Unselect);
reg_wizchip_spi_cbfunc(spi_rb, spi_wb);
wiz_NetInfo gGetNetInfo;
wiz_NetInfo gSetNetInfo = {
.mac = {0x00, 0x08, 0xdc, 0xab, 0xcd, 0xef},
.ip = {192,168,2,192},
.sn = {255, 255,255,0},
.gw = {192,168,2,1},
.dns = {130,130,130,130},
.dhcp = NETINFO_STATIC}; -
wizchip_setnetinfo(&gSetNetInfo);
HAL_Delay(100);
wizchip_getnetinfo(&gGetNetInfo);
HAL_Delay(100);
wizchip_init(bufSizeTx, bufSizeRx);
HAL_Delay(100);
uint16_t port = 8880;
socket(sn, Sn_MR_TCP, port, SF_TCP_NODELAY);
HAL_Delay(1000);
connect(sn, gSetNetInfo.ip, port);
HAL_Delay(1000);
/* USER CODE END 2 */
/* Infinite loop /
/ USER CODE BEGIN WHILE /
while (1)
/ USER CODE END WHILE */
97. /* USER CODE BEGIN 3 */
98. i ++;
99. send(sn, &mydata, strlen(mydata));
100. if (i == 2){
101. break;
- close(sn);
- /* USER CODE END 3 */
