hello,
I have been working with W5500 for a while for my project .
I have succeeded in initializing the chip after a while.
Now I am stuck at the TCP connection problem.
I am trying to make the W5500 chip as server and make connection . The issue is that i am stuck at the socket_listen State, I did all the things as per data sheet and related forum discussion.i will post my code bellow
main {
spi_data[0] = 0x00; //#
spi_data[1] = 0x39; //#
spi_data[2] = 0x00; //#
spi_data[3] = 0x00; //#
GpioDataRegs.GPBCLEAR.bit.GPIO57 = 1; //cs low //#
for (i=0;i<4;i++) //#
{ //# reading version register value (0x04)
SpiaRegs.SPITXBUF = (spi_data[i]<<8); //send frame //#
//rdata =(SpiaRegs.SPIRXBUF>>8); //recieve data //#
DELAY_US(29); //#
GpioDataRegs.GPBSET.bit.GPIO57 = 1; //#
version_data = SpiaRegs.SPIDAT; //#
DELAY_US(10);
// Reading PHYCFGR reg
spi_data[1] = 0x2E; //#
{ //# Reading PHYCFGR reg
DELAY_US(29); //#
phy_data = SpiaRegs.SPIDAT; //#
DELAY_US(10); //#
// Writing MR register for internal register initialization
spi_data[1] = 0x00; //#
spi_data[2] = 0x04; //#
spi_data[3] = 0x80; //#
for (i=0;i<4;i++) //# Writing MR register for internal register initialization
DELAY_US(29); //#
DELAY_US(80);
// Reading MR register for internal register initialization
for (i=0;i<4;i++) //# Reading MR register for internal register initialization
DELAY_US(29); //#
Mr_status = SpiaRegs.SPIDAT; //#
DELAY_US(10); //#
//Writing GAR
Gar_data[0] = 0x00; //#
Gar_data[1] = 0x01; //#
Gar_data[2] = 0x04; //#
Gar_data[3] = 0xC0; //#
Gar_data[4] = 0xA8; //#
Gar_data[5] = 0x00; //#
Gar_data[6] = 0x01; //#
GpioDataRegs.GPBCLEAR.bit.GPIO57 = 1; //cs low //# Writing GAR
for (i=0;i<7;i++) //#
// rdata =(SpiaRegs.SPIRXBUF>>8); //recieve data //#
DELAY_US(49); //#
DELAY_US(10);
//Reading GAR register
/*Gar_data[0] = 0x00; //#
Gar_data[2] = 0x00; //#
Gar_data[3] = 0x00; //#
Gar_data[4] = 0x00; //#
Gar_data[6] = 0x00; //#
for (i=0;i<7;i++) //# Reading GAR register
DELAY_US(49); //#
GAR_data = SpiaRegs.SPIDAT;
DELAY_US(10);*/
//Writing SUBR reg
Gar_data[1] = 0x05; //#
Gar_data[3] = 0xFF; //#
Gar_data[4] = 0xFF; //#
Gar_data[5] = 0xFF; //#
for (i=0;i<7;i++) //# Writing SUBR reg
DELAY_US(49); //#
DELAY_US(10);
//Writing SHAR reg
SHAR_data[0] = 0x00; //#
SHAR_data[1] = 0x09; //#
SHAR_data[2] = 0x04; //#
SHAR_data[3] = 0x00; //#
SHAR_data[4] = 0x08; //#
SHAR_data[5] = 0xDC; //#
SHAR_data[6] = 0x01; //#
SHAR_data[7] = 0x02; //#
SHAR_data[8] = 0x03; //#
GpioDataRegs.GPBCLEAR.bit.GPIO57 = 1; //cs low //# Writing SHAR reg
for (i=0;i<9;i++) //#
DELAY_US(59); //#
DELAY_US(10);
// WRITING Sipr Register
Gar_data[1] = 0x0F; //#
Gar_data[3] = 0xC0; //192 //#
Gar_data[4] = 0xA8; //168 //#
Gar_data[5] = 0x01; //1 //#
Gar_data[6] = 0x02; //2 //#
for (i=0;i<7;i++) //# WRITING Sipr Register
DELAY_US(49); //#
DELAY_US(10); //#
// Writing Sn_Mr register
spi_data[2] = 0x0C; //#
spi_data[3] = 0x21; //#
{ //# Socket n mode register(0001)
DELAY_US(29); //#
DELAY_US(10);
// Sn_Port register
port[0] = 0x00; //#
port[1] = 0x04; //#
port[2] = 0x0C; //#
port[3] = 0x13; //#
port[4] = 0x88; //#
for (i=0;i<5;i++) //#
{ //# source port num
DELAY_US(38); //#
DELAY_US(10);
//open command Sn_Cr register
spi_data[1] = 0x01; //#
spi_data[3] = 0x01; //open command //#
{ //# open command
DELAY_US(29); //#
DELAY_US(80);
//reading status register
spi_data[1] = 0x03; //#
spi_data[2] = 0x08; //#
{ //# reading status reg
SpiaRegs.SPITXBUF = (spi_data[i]<<8); //send frame //# expected value (0x13) {Sock_init}
DELAY_US(29); //#
DELAY_US(10);
while(status != 0x13);
// reading command register
{ //# reading command reg
SpiaRegs.SPITXBUF = (spi_data[i]<<8); //send frame //# expected value (0x00)
DELAY_US(29); //#
cmdRegStat = SpiaRegs.SPIDAT; //#
DELAY_US(10);
DELAY_US(29); //#
DELAY_US(10); //#
//Set destionation Ip address ###################################################
Dest_IP[0] = 0x00; //#
Dest_IP[1] = 0x0F; //#
Dest_IP[2] = 0x0C; //#
Dest_IP[3] = 0xC0; //#
Dest_IP[4] = 0xA8; //#
Dest_IP[5] = 0x01; //#
Dest_IP[6] = 0x01; //#
for (i=0;i<7;i++) //# WRITING DESTIP Register
DELAY_US(49); //#
DELAY_US(10);
//Set Destination port num ########################################################
port[0] = 0x00; //#
port[1] = 0x10; //#
port[2] = 0x0C; //#
port[3] = 0x13; //#
port[4] = 0x88; //#
{ //# destination port num
DELAY_US(38); //#
DELAY_US(10);*/
// listen/connect command register (Sn_CR)
spi_data[0] = 0x00; //# @@@@@@@@@@
spi_data[1] = 0x01; //# @ @
spi_data[2] = 0x0C; //# @ @
spi_data[3] = 0x02; //# @ @
GpioDataRegs.GPBCLEAR.bit.GPIO57 = 1; //cs low //# @ @
for (i=0;i<4;i++) //# @ @
{ //# writing listen 0x02(server)/
SpiaRegs.SPITXBUF = (spi_data[i]<<8); //send frame //# connect(0x04)(client) command to
} //#Command register @
//rdata =(SpiaRegs.SPIRXBUF>>8); //recieve data //# @ @
DELAY_US(29); //# @ @
GpioDataRegs.GPBSET.bit.GPIO57 = 1; //# @ @
DELAY_US(800000);
DELAY_US(29); //#
cmdRegStat_aft = SpiaRegs.SPIDAT; //#
DELAY_US(10);
status_2 = SpiaRegs.SPIDAT;
// Read Status register
while (status_listen != 0x17)
SpiaRegs.SPITXBUF = (spi_data[i]<<8); //send frame //# expected value (0x14) {listen}
DELAY_US(29); //#
status_listen = SpiaRegs.SPIDAT; //#
DELAY_US(10);
// while (status_listen != 0x17) // wait for connection establishment
// reading interupt register
spi_data[1] = 0x02; //#
{ //# reading interrupt reg
SpiaRegs.SPITXBUF = (spi_data[i]<<8); //send frame //# expected value (##) {listen}
DELAY_US(29); //#
int_stat = SpiaRegs.SPIDAT; //#
DELAY_US(10);
//if ()
// loop ends
} //main ends
somebody do help as soon as possible
@becky
Hello.
I see you have edited the code in the notification.
What change did you make?
I applied this to your code.
It makes the code readable.
read - VERSIONR
read - PHYCFGR
write - MR (0x80)
read - MR
write - GAR(192 168 0 1)
read - GAR
write - SUBR ( 255 255 255 0)
write - SHAR (0x00 0x08 0xdc 0x01 0x02 0x03)
write - SIPR (192 168 1 2)
write - Sn_MR (0x21)
write - Sn_Port(0x13 0x88)
write - Sn_CR(0x01)
read - Sn_SR
read - Sn_CR
read - PHYCFGR
write - Sn_DIPR(192 168 1 1)
write - Sn_DPORT(0x13 0x88)
write - Sn_CR(0x02)
read - Sn_CR
read - Sn_SR
read - Sn_IR
I have summarized your code as above.
But this took too long. It would be nice to show it in pseudocode for easy viewing.
You do not need to fill in Socket Destination IP and Socket Destination Port when using W5500 as a server.
This is a register for connecting to the server when in client mode.
Please refer to image.
However, writing a Destination does not cause problems when running in server mode.
I think your problem is that the gateway address is 192.168.0.1 and the source IP address is 192.168.1.2.
This is not the right network bandwidth. Match the network bandwidth of the two addresses.
The same applies to the network bandwidth of the client, and the gateway address and the client address must not be the same.
@becky
Thanks for the help sir. And sorry for the inconvenience caused ,
i was able to solve the issue for now, i was able to establish the connection.(Mistake was with an array name)
But through herculese only. My code gets stuck at the Listen state, and only after using herculese the conection gets established.
I dont know why its doesnot work with the code.
Another doubt is regarding the Sn_TXBUF_SIZE , Sn_TX_FSR, Sn_TX_RD ,do these registers belongs to the Socket 0 Register or the Socket 0 TX Buffer.
Doubt arised as i was tring to send some 8 byte data am getting so many junk values along with the data
@becky
Sir ,
It would be a great help if you could help me clear these things for me.
For sending data , i believe the steps are like this right,
- Configure the Size of TX_Buffer
- Read the Starting Offset address from TX_RD, for writing Tx_data to TX buff
- Check the data to be written is less than or equal to the free size.
- Write data to Tx_Buffer
- Write the Number of bytes of transmitting data to TX_WR.(if i am sending a 8 byte data for the test purpose do i write value 0x0008 to the TX_WR?)
- Issue Send Command.
@becky
By doing so am able transmit data but am getting so many junk values along with data. and Large number of packets are being send.
this is the data captured. as you can see i have send " AA AA AA AA AA AA AA" as data for a single time. But am getting data of length 1460 3 times and 1 packet of 629.
4 images are of 4 packets.
I wrote the value for TX_WR as 0x07 as am sending 7 bytes.
and data writing offset address which i got from TX_RD reg
TCP Server waits for Client connection in listen state. After that, when the Client connects, it changes to Establish state. This is normal operation.
2 → Read the offset address from TX_RD → Sn_TX_WR.
4 → You should calculate Write Offset Address and write data to this address(=addrsel).
#define WIZCHIP_TXBUF_BLOCK(N) (2+4*N) //< Socket N Tx buffer address block
ptr = getSn_TX_WR(sn);
addrsel = ((uint32_t)ptr << 8) + (WIZCHIP_TXBUF_BLOCK(sn) << 3);
5 → Write the value increased by the amount of data to be transmitted of the existing Sn_TX_WR value. If Sn_TW WR value is 0x0070, you should write the 0x0078 to send 8byte data.
Sorry I didn’t get that well.
Can you explain it a bit more,?
For you information am not using the IO library.
Did u mean to Read the Offset address from the TX_RD and write the address as the starting address to the TX_BUFFER register?
And I am getting same values from TX_RD and TX_WR, is this normal?
W5500 data sheet is so incomplete that i have to depend on the forum for simple doubts and that too takes days to get replay
Sorry.
Please refer to ioLibrary Driver.
You should read the Sn_TX_WR to get offset address. Sn_TX_RD is not.
If you increase the value to send data to Sn_TX_WR and set a send command and complete to sending data, Sn_TX_RD is automatically incremented and equal to Sn_TX_WR.
What is Sn_TX_BASE, I don’t see there is such a register.
i did Read the TX_WR ( i believe this is the offset address )
And to calculate the write start address , i believe this must be added with the TX_BASE you said, right?!
And I didnt understand what TX_Base.
After socket connection got established. I did like this.
- Read TX_WR register , assume the value be (0x43E8)
- Write data to the TX_Buffer with adress as (0x43E8) and Control Phase as 0x14, am Writing a 3 byte data
- Increment the value as 0x43E8 + 0x03
- Write the incremented value to TX_WR register.
- Issue the SEND command.
- Wait for the command to be executed.
Am able to send data , but monitoring through wire shark is give me data along with junk value, insted of 8 byte data am getting like 4 packets of 1460 bytes. Where in the first packet required data is at the staring of data byte , and going to inner on other packets
Sorry this is about w5100s and I’m confused.
This is correct.
and why is this happening you think?
@becky @Eugeny @irina_kim ?? anyone?
I think it’s because you wrote 0x0008 in Sn_TX_WR.
The length of data is calculated by the difference between Sn_TX_WR and Sn_TX_RD.
So if the Sn_TX_WR(=Sn_TX_RD) value is 0xe937 and you write 0x0008 to Sn_TX_WR,
the 0x16d0 bytes of data (1460x4), which is the difference between 0x0008 and 0xe937, be sent.
