W6100-evb-pico
What will be the Power or Current requirement
when i power on the board with the USB i.e 5v. -
In case if i power on the board with 3V3 what will
be the Power or Current requirement.
W6100-evb-pico
W6100-EVB-Pico has RP2040 and W6100.
W6100’s MAX Power is 265mA (Test Condition: VDD=3.3V, AVDD=3.3V, Ta = 25°C).
you can find it on W6100’s datasheet
in case of RP2040, power usage will vary depending on what features you implement and how
much. you can refer RP2040’s document
I don’t know the exact power requirements, but a 5V/1A power source is usually sufficient.
W6100-EVB-Pico has LDO(5V to 3.3V). so I recommand to you to supply 5V to VBUS or use Micro
USB
