Hello, im having trouble with the WIZVSP usage, when I enter the serial number, I get the following error:
Excepcion not controlled in the app.
How can I repair this?
Hello. First, please answer the questions below.
Also, please capture the entire error screen.
Im using Windows 11
I tried all the old versions and the same error keep appearing when I enter the serial number
The screenshot is the following (is in spanish)
Try reinstalling VSP by following the process below.
I tried that steps, and keeps without working.
We have tried the same steps on a new PC but we have never encountered this error.
What happens if you click on Details or Continue in the error window?
Also, Microsoft .NET Framework 4.5.2 or a later update is required to run the WIZVSP program on Windows. Please check if you have the latest version.
Hello, if I click continue, the error keeps appearing.
If I click details, the following appears:
I have the latest version of .NET Framework installed, and I tried to repair the installation too.
