Hi @Theo
Thanks for your time.
Just few doubts because it is the first time i use the wiznet device. So your are saying this fw for 7500 p is wrong
and i should use the one you provided in the github page…
Can i still use this too to download the fw in the wiznet by using the ethernet port?
my current situation with the fw downloaded inside
the github link you provided are c and h files not a bin… how can i do that?
My task is to communicate with wiznet with uart with stm32… the fw link you provided is ok?
I would like to know the workflow…
I suppose i have to create a .bin from the github repo you provided…
which ide you reccomend?
One i have created the .bin i can upload on it by using
How to use ISP tool | WIZnet Document System ?
Is it correct?
Can i use this guide but with the github repo for 7500 p?
Once i did where i can find the protocol fopr communicating with 7500 p?
Last question… since my ultimate task it is to use the wiznet as a webserver …
Is it correct to use such library ?
The point is that i would like to create a .bin to have the library for the webserver and also library for uart just to test the communication with stm32.
Once i have download the .bin inside the wiznet … where i can find the documentatio about how to create the packet to transmit ?
I hope to be enough clear
Last observation is that inside the wiznet7500 p there is the fw in the attachments…
But when i try to communicate in uart with him with stm32 i don’t get any answer back…
Moreover i don’t know the protocol
Thanks for explaining
WIZ750SRv129_incl_Boot.bin (66,5 KB)
