I am working with a custom board using W5500 and I noticed some key differences between this schematic versus the evaluation board one - W5500-EVB. I have listed them below:
Does leaving the “RSVD” pins (Especially pin 23) NC have an affect on the performance of the chip or anything else? I noticed they are pulled down in the eval board.
Pin 37 (nRST) is pulled high in the eval board. I was wondering why it would be pulled high? Our processor controls it and we have pulldown to make sure it is reset on power up
RXP and RXN signals have 6.8nF caps each in series with their connector. We don’t have these caps, I am assuming these are for removing the DC aspect of the signals. We are using this connector: 74984104400. Could this be an issue?
There is a current limiting resistor (R30 - 10 ohm) on the TXP pin in the evaluation board, we don’t have this. Could this be an issue?
Lastly, we are using 0.1uF instead of 22nF for C17 and C26. Could this be an issue
