We recently purchased a wizwiki 7500 eval board so we can test the W7500 chip before the W7500P is released. In order to test I went ahead and downloaded the W7500 Master.zip with all the libraries and evaluation programs that have been created. I compiled httpServer with arm-none-eabi-gcc and flashed the board with binary file that was created. Compiling has worked, but I cannot access the http server via my browser. The IP address set in the example program is 192.168.1.98, subnet 255.255.255.0, and gateway 192.168.1.1. I’ve tried typing 192.168.1.98 into my web browser and haven’t been able to get any kind of a landing page. Correct me if I’m wrong, but I believe this sample program allows me to control certain functions of the board via browser. Here are some things I’ve gathered so far.
I can ping the board. Meaning the ip settings have been assigned properly and the board is, in fact, running the httpServer code. I would suspect that I should be able to see port 80 open if this is a web server I am unable to see ANY ports open. When initializing the board (resetting) I do receive messages in my serial console and it seems as if the code is running. Below you can see my results. Please steer me in the correct direction on how to get this working and/or tell me what I’m doing wrong.
/*** PING RESULT ***/
PING 192.168.1.98 (192.168.1.98): 56 data bytes
64 bytes from 192.168.1.98: icmp_seq=0 ttl=128 time=0.355 ms
64 bytes from 192.168.1.98: icmp_seq=1 ttl=128 time=0.243 ms
64 bytes from 192.168.1.98: icmp_seq=2 ttl=128 time=0.261 ms
64 bytes from 192.168.1.98: icmp_seq=3 ttl=128 time=0.343 ms
/*** PORT SCAN RESULT ***/
Nmap scan report for 192.168.1.98
Host is up (0.00022s latency).
All 65535 scanned ports on 192.168.1.98 are closed
Nmap done: 1 IP address (1 host up) scanned in 2.92 seconds
/*** SERIAL CONSOLE RESULT ***/
……PHY is linked.
MAC ADDRESS : 00:08:DC:71:72:77
IP ADDRESS : 192.168.001.098
GW ADDRESS : 192.168.001.001
SN MASK: 255.255.255.000
=== List of Web content in code flash ===
[1] Χ[
Ã{ÿpö”wì=Ýo·42[õ½Ü8$fËØÛË&z=9éfçþ£½
+owç, -1107993806 byte, [ … ]
[2] fËØÛË&z=9éfçþ£½
+owç, -411603157 byte, [ … ]
[3] ½ávæÑY:ñ)ËÆXÙ õ
âImYH0
, -502625547 byte, [ … ]
[4] H0
, 209988864 byte, [ … ]
[5] ”I0Zµ!LEDÊêð¨Aì¿&EâÄ$0N=Æ,1(
ôi²ñXÍÞ, 650112065 byte, [ … ] [6] âÄ$0N=Æ,1( ô
i²ñXÍÞ, 1611141125 byte, [ … ]
[7] ²ñXÍÞ, -1562054376 byte, [ … ]
[8] 8Ì
CcáäÀ_
\ÉiðPGïïÓ X©
SªÈò, 1196432520 byte, [ … ]
[9] X©
SªÈò, 488013642 byte, [ … ]
[10] V¥!K²,(.0¦ÀþjÌ
@U¼¤×d¶x0RKèÈlÉV¥Z!ZbÈ9?9²+Bedµ
»ØjsL¨$´/)^ Â&~L2’(Ä’¤p°x3aÒÚ7<5¼ß>ÊÀ¡ý!dA
g60ƨÔm%´á7xÔ1êØ/
¶@±ÉqGà_è ©X`ÉàÁÛf, -2063479793 byte, [ … ]
[11] ¤×d¶x0RKèÈlÉV¥Z!ZbÈ9?9²+Bedµ
g60ƨÔm%´á7xÔ1êØ/
¶@±ÉqGà_è ©X`ÉàÁÛf, 1650073946 byte, [ … ]
[12] 9²+Bedµ
g60ƨÔm%´á7xÔ1êØ/
¶@±ÉqGà_è ©X`ÉàÁÛf, 512756062 byte, [ … ]
[13] L2’(Ä’¤p°x3aÒÚ7<5¼ß>ÊÀ¡ý!dA
g60ƨÔm%´á7xÔ1êØ/
¶@±ÉqGà_è ©X`ÉàÁÛf, 893138906 byte, [ … ]
[14] ÊÀ¡ý!dA
g60ƨÔm%´á7xÔ1êØ/
¶@±ÉqGà_è ©XÉàÁÛf, -1878292968 byte, [ … ] [15] 7xÔ1êØ/ ¶@±ÉqGà_è ©X
ÉàÁÛf, -1600974872 byte, [ … ]
[16] ÉàÁÛf, 341117577 byte, [ … ] [17] dÈò26HµáUKTñÀHêe¯+r2bÀ´ã¾R³AAn z(@#ÐH6;#hÉæ):WAA^Zz&, 478939925 byte, [ … ] [18] +r2bÀ´ã¾R³AAn z(@#ÐH6;#hÉæ):WAA^Zz&, 1076397714 byte, [ … ] [19] 6;#hÉæ):WAA^Zz&, 2521690 byte, [ … ] [20] R, 1015285034 byte, [ … ] [21] , 614012010 byte, [ … ] [22] , -1054578852 byte, [ … ] [23] ÕA¤wSfï#øßÖs0hÿ&ñ·B
m{Ar0Ú
§I±zÎøqA²¯(@>ñÀ×Õ·Íí,ÂË;Y0¼Ñ0Q0rÄ[a*#Ha0e2ȲÀ¢XYH.m|, -1790789647 byte, [ … ]
[24] {Ar0Ú
§I±zÎøqA²¯(@>ñÀ×Õ·Íí,ÂË;Y0¼Ñ0Q0rÄ[a#Ha0e2ȲÀ¢XYH.m|, -1349733823 byte, [ … ]
[25] >ñÀ×Õ·Íí,ÂË;Y0¼Ñ0Q0rÄ[a*#Ha0e2ȲÀ¢XYH.m|, 1497072331 byte, [ … ]
[26] Ñ0Q0rÄ[a#Ha0e2ȲÀ¢XYH.m|, -936758683 byte, [ … ]
[27] YH.m|, 1310974744 byte, [ … ]
[28] 4R¥ËÜmaß’±, 167817620 byte, [ … ]
[29] ¹F GìYFg m1°N R¸O½¿¨6IùIÏÕø¾«mD¦QÂ¥X©Ü&fÊ’,dº$ÔIÐZq54”ßé+O ¢óøÏ\ !l, -2091770103 byte, [ … ]
[30] ¨6IùIÏÕø¾«mD¦QÂ¥X©Ü&fÊ’,dº$ÔIÐZq54”ßé+O ¢óøÏ\ !l, -1453808190 byte, [ … ]
[31] Ê’,dº$ÔIÐZq54”ßé+O ¢óøÏ\ !l, 137720154 byte, [ … ]
[32] é+O ¢óøÏ\ !l, 276338841 byte, [ … ]
[33] ð¥j$@,
¯¦$ÆP÷H$·I9¬¨3äk, -1215814584 byte, [ … ]
[34] 9¬¨3äk, -146456980 byte, [ … ]
[35] 2ÌÌK@8;Çv4¾
V, 1116055852 byte, [ … ]
[36] ¨¢k:)”!ËZ=n4Hk@KR04±Mò¥1z{¡Ê@À¸7Ó×&57ÐÊúXZ¨
nv, 1384926016 byte, [ … ]
[37] ±Mò¥1z{¡Ê@À¸7Ó×&57ÐÊúXZ¨
nv, 934854686 byte, [ … ]
[38] &57ÐÊúXZ¨
nv, 1368431048 byte, [ … ]
[39] SBa
éºw (PU Wx¾DX)x1-5GKÉ)ÈM w(X¨æ”oí
\ H5ö/Æ9F¢k´,ÕÍUßroªÃHS¶¸$²Aw4´eJRD¾ZrØa+t`dõS½, 1431343400 byte, [ … ]
[40] ¾DX)x1-5GKÉ)ÈM w(X¨æ”oí
\ H5ö/Æ9F¢k´,ÕÍUßroªÃHS¶¸$²Aw4´eJRD¾ZrØa+t`dõS½, 671250324 byte, [ … ]
[41] oí
\ H5ö/Æ9F¢k´,ÕÍUßroªÃHS¶¸$²Aw4´eJRD¾ZrØa+t`dõS½, 33718379 byte, [ … ]
[42] UßroªÃHS¶¸$²Aw4´eJRD¾ZrØa+t`dõS½, 1380607237 byte, [ … ]
[43] ZrØa+t`dõS½, 361068584 byte, [ … ]
[44] A)H(v=¼â
4J½3G@7´Å$¶@saÒ7·UYÌp U@ñL¡¸9P, -1274508643 byte, [ … ]
[45] saÒ7·UYÌp U@ñL¡¸9P, -1803543823 byte, [ … ]
[46] P, 809206664 byte, [ … ]
[47] ?ã¹ê{´¤1Lpº¤
Î|Júë9ÅB¶R!ä’òç¹PrLPµvòÈh)àûrci?¬òáTÑÄf><Z¤ÐPQ¥î¨¸QuÀáTMÓªR ¸²¢fDD+DB× ÃÆTÔß!°Ìªëmè$G®XbpòGM*È4åÏÑ D.&9f<\
Òl, 361835258 byte, [ … ]
[48] 9ÅB¶R!ä’òç¹PrLPµvòÈh)àûrci?¬òáTÑÄf><Z¤ÐPQ¥î¨¸QuÀáTMÓªR ¸²¢fDD+DB× ÃÆTÔß!°Ìªëmè$G®XbpòGM*È4åÏÑ D.&9f<\
Òl, -1253028750 byte, [ … ]
[49] h)àûrci?¬òáTÑÄf><Z¤ÐPQ¥î¨¸QuÀáTMÓªR ¸²¢fDD+DB× ÃÆTÔß!°Ìªëmè$G®XbpòGM*È4åÏÑ D.&9f<\
Òl, -2109981178 byte, [ … ]
[50] PQ¥î¨¸QuÀáTMÓªR ¸²¢fDD+DB× ÃÆTÔß!°Ìªëmè$G®XbpòGM*È4åÏÑ D.&9f<\
Òl, 1150510754 byte, [ … ]
[51] +DB× ÃÆTÔß!°Ìªëmè$G®XbpòGM*È4åÏÑ D.&9f<\
Òl, -341180010 byte, [ … ]
[52] $G®XbpòGM*È4åÏÑ D.&9f<\
Òl, 776249366 byte, [ … ]
[53] <\
Òl, 1774792962 byte, [ … ]
[54] nÀ¹!ª, 226604161 byte, [ … ]
[55] ùF .vbC0âØRp*£µ4<}%*@huU£§Èpt
,#s%âjÖÑGö¶äï¿Z
U¦ø¨_t©8à¾û
q0 ¾&ÐY, -1247598068 byte, [ … ]
[56] }%*@huU£§Èpt
`,#s%âjÖÑGö¶äï¿Z
U¦ø¨_t©8à¾û
q0 ¾&ÐY, 270861171 byte, [ … ]
[57] ÑGö¶äï¿Z
U¦ø¨_t©8à¾û
q0 ¾&ÐY, -1869389942 byte, [ … ]
[58] 8à¾û
q0 ¾&ÐY, -2097147187 byte, [ … ]
[59] rmoÚ¦Q%e¶}+àFÌÙ´ã”#)Úa01CxXÆP¼H¤³Wl Saî@,Á]lY½Yp(¤E3yùìqfäªñc D, -1260794741 byte, [ … ]
[60] Úa01CxXÆP¼H¤³Wl Saî@,Á]lY½Yp(¤E3yùìqfäªñc D, 1471353736 byte, [ … ]
[61] Saî@,Á]lY½*Yp(¤E3yùìqfäªñc D, 2033422917 byte, [ … ]
[62] qfäªñc D, 341056842 byte, [ … ]
[63] D¨È {/ótCÒ, -921829172 byte, [ … ]
[64] à ¥ZDVîàðò
ÍÆb˱ðÂr%PëÇQîÙ!”Ä0Íyí
²
], -1029902159 byte, [ … ]
[65] PëÇQîÙ!”Ä0Íyí
²
], 227147869 byte, [ … ]
[66] ¤f\eòYZsÚÐ1gNÏ
<ÉÅÕAg* PêÍ¡@ÎÐFEoaòz?¶Ýîø LÉñ/ $¿à
kR!ÿø˪S;I¥%ÈE8°êB7ò%MÅÐÂRkµä]¬EPQ¼ç
, -1664135531 byte, [ … ]
[67] ÕAg* PêÍ¡@ÎÐFEoaòz?¶Ýîø LÉñ/ $¿à
, 17696644 byte, [ … ]
[68] ?¶Ýîø LÉñ/ $¿à
, 269689170 byte, [ … ]
[69] ˪S;I¥%ÈE8°êB7ò%MÅÐÂRkµä]¬EPQ¼ç
, 118026880 byte, [ … ]
[70] ÂRkµä]¬EPQ¼ç
, -257845102 byte, [ … ]
[71] ÂI;-ÐTAC”P¢?}o{tâÄ< Yì¤vv”)r5Ö, 1863343878 byte, [ … ]
[72] tâÄ< Yì¤vv”)r5Ö, 14038422 byte, [ … ]
[73] 6pNÁCì6iaÓÛõïCb¯\÷H
=S
àPúk~ºTëÀ£à2 lÁË, -2003745913 byte, [ … ]
[74] H
=S
àPúk~ºTëÀ£à2 lÁË, -526150976 byte, [ … ]
[75] lÁË, -1978296541 byte, [ … ]
[76] Ô, 2030600545 byte, [ … ]
[77] 4eC
Í îb`¯ÁÕ:, 853994060 byte, [ … ]
[78] O Èد’GJÈ°g.
ÂÙl$> ’ÃõpX|, -1969825342 byte, [ … ]
[79] ’ÃõpX|, 623717575 byte, [ … ]
[80] z¬tÑ!æLäÁzIKQé60Sªá®GftDP$à öºÔB6Ç\K£ddXûDq#ÕÔ´j°“A¯@±F#biPBBÒXÆ
¸8Å×ÁB¸S-Ï&, 355920135 byte, [ … ]
[81] á®GftDP$à öºÔB6Ç\K£ddXûDq#ÕÔ´j°“A¯@±F#biPBBÒXÆ
¸8Å×ÁB¸S-Ï&, 140298038 byte, [ … ]
[82] dXûDq#ÕÔ´j°“A¯@±F#biPBBÒXÆ
¸8Å×ÁB¸S-Ï&, -1321204049 byte, [ … ]
[83] biPBBÒXÆ
¸8Å×ÁB¸S-Ï&, -1197587840 byte, [ … ]
[84] &, -999422438 byte, [ … ]
[85] $)t J²gáÔÄ j
A[ÜE¡
&Ë
´£BÖiåXP, -2053028388 byte, [ … ]
[86] ´£BÖiåXP, -357956699 byte, [ … ]
[87] |R+DmP¤çä0 1ë«
iÆÎ Ò S(0
1”ùÌb3C@jE°KÒ¡(
$C¢iù!Jæ
!@F9qÍ|Àê³æÙ0nE H»L< , 673323029 byte, [ … ] [88] Ò S(0 1”ùÌb3C@jE°KÒ¡( $C¢iù
!Jæ!@F9qÍ|Àê³æÙ0nE
H»L<
, 92301888 byte, [ … ]
[89] KÒ¡(
$C¢iù!Jæ
!@F9qÍ|Àê³æÙ0nE H»L< , 1178603809 byte, [ … ] [90] Í|Àê³æÙ0nE
H»L<
, 117478669 byte, [ … ]
[91] TX”²
, -1783504022 byte, [ … ]
[92] ¦²iMMÜWã ¸A^àUL^
Â7 ÜaJµ&{,¹lfL¸;!
(E1¶ê1¡$1ÀNìÿ!IH4«¿”ºó°XK$Sh=#SB¼¥a!¥î+ÉB×3R,dz#blÌF&|(Ü&1Ù6j®°J 6õNL©=/T¡>ñ·f!$gÀP!Ø èÕ¯Æñp, 1280696469 byte, [ … ] [93] ÜaJµ&{,¹lfL¸;! (E1¶ê1¡*$1ÀNìÿ!IH4«¿”ºó°XK$Sh=
èÕ¯Æñp, 1001933959 byte, [ … ]
[94] 1¶ê1¡$1ÀNìÿ!IH4«¿”ºó°XK$Sh=#SB¼¥a!¥î+ÉB×3R,dz#blÌF&|(Ü&1Ù6j®°J 6õNL©=/T¡>ñ·f!$gÀP!Ø èÕ¯Æñp, -1422652600 byte, [ … ] [95] ó°XK$Sh=
èÕ¯Æñp, 303473946 byte, [ … ]
[96] î+ÉB×3R,dz#blÌF&|(Ü&1Ù6j®°J
èÕ¯Æñp, -2142856500 byte, [ … ]
[97] Ü&1Ù6j®°J
èÕ¯Æñp, 1412382121 byte, [ … ]
[98] >ñ·f!$gÀP!Ø
èÕ¯Æñp, -1325006736 byte, [ … ]
[99] ÎÔ,kkwÅ@CB!5_Z·:ÛP¶æÁJp!ÏTDÈ56¡”¸Ò@E¯0C8HA<Q”äy¨[rÔ qÃ?VÈ
])÷@àt|è§$ñ,ÕKDÍ\kÁ¤´d~ØG«pd$ ¨I, 985104730 byte, [ … ]
[100] P¶æÁJp!ÏTDÈ56¡”¸Ò@E¯0C8HA<Q”äy¨[rÔ qÃ?VÈ
])÷@àt|è§$ñ,ÕKDÍ\kÁ¤´d~ØG«pd$ ¨I, 80918562 byte, [ … ]
[101] ¯0C8HA<Q”äy¨[rÔ qÃ?VÈ
])÷@àt|è§$ñ,ÕKDÍ\kÁ¤´d~ØG«pd$ ¨I, 550771865 byte, [ … ]
[102] È
])÷@àt|è§$ñ,ÕKDÍ\kÁ¤´d~ØG«pd$ ¨I, 1556956235 byte, [ … ]
[103] ¤´d~ØG«pd$ ¨I, 1225917337 byte, [ … ]
[104] |ÐU£ÒA©477@XÀD?Óþ, -1476329773 byte, [ … ]
[105] UØËA¤¤W$B,¢, 625152270 byte, [ … ]
[106] þÀq&Ê<$, -290401024 byte, [ … ]
[107] %E]0=¼«bæÔþ
p¸ÕÙlKµ=¹$FÜ, -640305040 byte, [ … ]
[108] Kµ=¹$FÜ, -2130919172 byte, [ … ]
[109] å’Q É´ÄÖ;hP¡ËÑB
©áÜÌH¢;6,ÇF+ó
LZ ì«´=p@ÃóSp4À”ÌH^{Ê!º
z5OX$.O©ÉÈ[’(üÑ
¯ó¬C, 302061204 byte, [ … ]
[110] áÜÌH¢;6,ÇF+ó
z5OX$.O©ÉÈ[’(üÑ
¯ó¬C, 1182896515 byte, [ … ]
[111] LZ ì«´=p@ÃóSp4À”ÌH^{Ê!º
z5OX$.O©ÉÈ[’(üÑ
¯ó¬C, -1070305197 byte, [ … ]
[112] H^{Ê!º
z5OX$.O©ÉÈ[’(üÑ
¯ó¬C, -1454405842 byte, [ … ]
[113] ’(üÑ
¯ó¬C, -1533848702 byte, [ … ]
[114] µãfBë± Â¯¬Twp)¸§Ã\rñF
·c, -1481102992 byte, [ … ]
[115] \rñF
·c, -1985821553 byte, [ … ]
[116] ªãüÁpÌFºã\ 9J(båp ýCÓB:Qp)AB¯4oA0Á¶äJcèT±, yÀñ5! 0##Jú, 1646822218 byte, [ … ] [117] CÓ
yÀñ5!
0##Jú, 1665799908 byte, [ … ]
[118] ,
yÀñ5!
0##Jú, 149487641 byte, [ … ]
[119] #Æ(ääj0©, -1508380219 byte, [ … ]
[120] bÌUX(0løQ)TÂi<hL)ØàG¤!.wL8NÞ/hjà¿OA0A´ð±2ÉÌ^ÁJ9cñ¸Ç§ (, -1704444798 byte, [ … ]
[121] ØàG¤!.wL8NÞ/hjà¿OA0A´ð±2ÉÌ^ÁJ9cñ¸Ç§ (, -1802117014 byte, [ … ]
[122] A0A´ð±2ÉÌ^ÁJ9cñ¸Ç§ (, -1480083326 byte, [ … ]
[123] B
dð6\aq¸ÒF$ÆEQº¦X¨ò«n
Àða@·LJ:ÐéÅIrKUäfB¸YDhgbÆu~, 38897989 byte, [ … ]
[124] ò«n
Àða@·LJ:ÐéÅIrKUäfB¸YDhgbÆu~, 1265781189 byte, [ … ]
[125] äfB¸YDhgbÆu~, -1834323194 byte, [ … ]
[126] ¢9îgmÀWï©Õ.%¦:DÆSâ?dðSZ t¨Öȹ2, 1150827026 byte, [ … ]
[127] ?dðSZ t¨Öȹ2, 549814464 byte, [ … ]
[128] ¨¸´ñc¢a]÷9&àVÁX2V±¤
¨N]-Ú@Ts¼
=ÀÅ
Ò, 72751840 byte, [ … ]
[129] X2V±¤
¨N]-Ú@Ts¼
=ÀÅ
Ò, -2039262196 byte, [ … ]
[130] ÀÅ
Ò, 447251124 byte, [ … ]
[131] ¡1|¤ÀÈÀù5t6èrbFæP a)
Pà gf±>±ML
ëV°k:@öô7KT
öÉ° Upû ÍÖ«U´N#ÒM°Íâ6_Z2:¡
èE ’Ñ.Â:»Ñ8 DÛXÍP uc¨Ò#ª&è¢8Ì!Gß(Í0Áj¢¸©£üuú1ñTCµ«°DZ/i$)±RÃB0 ÈàÖ$ 0Ø4(Ûj)ô ^ºïx©DÀC2©’¸7Lc¬ Rx°P@@F Gh ½ÃRZ%H
³å¥ FD)³f~DÐ᱿a &@t!eTb´8¼)%<Ò7tdÞ¦Ñ/²h ÈvPRåA|DM§iìÍaZ]þEì°Z&I$Æ.Ép AÔk«)Ũ LÔ^¦h$ɶ)æPy˺¢4!§jTñ”.e5r1Eînf0p, 1343284806 byte, [ … ]
[132]
Pà gf±>±ML
ëV°k:@öô7KT
³å¥ FD)³f~DÐ᱿a &@t!eTb´8¼)%<Ò7tdÞ¦Ñ/²h ÈvPRåA|DM§iìÍaZ]þEì°Z&I$Æ.Ép AÔk«)Ũ LÔ^¦h$ɶ)æPy˺¢4!§jTñ”.e5r1Eînf0p, 1806718699 byte, [ … ]
[133] 7KTöÉ° Upû ÍÖ«U´N#ÒM°Íâ6_Z2:¡ èE ’Ñ.Â:»Ñ8 DÛXÍP uc¨Ò#ª&è
Gh
½ÃRZ%H³å¥ FD)³f~DÐ᱿a &@t*!eTb´8¼)%<Ò7td*Þ¦Ñ/²h ÈvPRåA|D*M§iìÍaZ]þEì°Z&I$Æ.Ép AÔk«)Ũ LÔ^¦h$ɶ)æPy˺¢4!§jTñ”.e5r1Eînf0p, 277094651 byte, [ … ] [134] U´N#ÒM°Íâ6_Z2:¡ èE ’Ñ.Â:»Ñ8 DÛXÍP uc¨Ò#ª&è
Gh
½ÃRZ%H³å¥ FD)³f~DÐ᱿a &@t*!eTb´8¼)%<Ò7td*Þ¦Ñ/²h ÈvPRåA|D*M§iìÍaZ]þEì°Z&I$Æ.Ép AÔk«)Ũ LÔ^¦h$ɶ)æPy˺¢4!§jTñ”.e5r1Eînf0p, 228669953 byte, [ … ] [135] ’Ñ.Â:»Ñ8 DÛXÍP uc¨Ò#ª&è
Gh
½ÃRZ%H³å¥ FD)³f~DÐ᱿a &@t*!eTb´8¼)%<Ò7td*Þ¦Ñ/²h ÈvPRåA|D*M§iìÍaZ]þEì°Z&I$Æ.Ép AÔk«)Ũ LÔ^¦h$ɶ)æPy˺¢4!§jTñ”.e5r1Eînf0p, 54789270 byte, [ … ] [136] ÍP uc¨Ò#ª&è
Gh
½ÃRZ%H³å¥ FD)³f~DÐ᱿a &@t*!eTb´8¼)%<Ò7td*Þ¦Ñ/²h ÈvPRåA|D*M§iìÍaZ]þEì°Z&I$Æ.Ép AÔk«)Ũ LÔ^¦h$ɶ)æPy˺¢4!§jTñ”.e5r1Eînf0p, 567031815 byte, [ … ] [137] (Í0Áj¢¸©£üuú1ñTCµ«°DZ/i$)±RÃB0 ÈàÖ$ 0Ø4(Ûj)ô ^ºïx©DÀC2©’¸7Lc¬ Rx°P@@F Gh ½ÃRZ%H
³å¥ FD)³f~DÐ᱿a &@t*!eTb´8¼)%<Ò7tdÞ¦Ñ/²h ÈvPRåA|DM§iìÍaZ]þEì°Z&I$Æ.Ép AÔk«)Ũ LÔ^¦h$ɶ)æPy˺¢4!§jTñ”.e5r1Eînf0p, -1253878543 byte, [ … ]
[138] DZ/i$)±RÃB0 ÈàÖ$
Gh
½ÃRZ%H³å¥ FD)³f~DÐ᱿a &@t*!eTb´8¼)%<Ò7td*Þ¦Ñ/²h ÈvPRåA|D*M§iìÍaZ]þEì°Z&I$Æ.Ép AÔk«)Ũ LÔ^¦h$ɶ)æPy˺¢4!§jTñ”.e5r1Eînf0p, -667940316 byte, [ … ] [139] )ô ^ºïx©DÀC2©’¸7Lc¬ Rx°P@@F Gh ½ÃRZ%H
³å¥ FD)³f~DÐ᱿a &@t*!eTb´8¼)%<Ò7tdÞ¦Ñ/²h ÈvPRåA|DM§iìÍaZ]þEì°Z&I$Æ.Ép AÔk«)Ũ LÔ^¦h$ɶ)æPy˺¢4!§jTñ”.e5r1Eînf0p, 140710988 byte, [ … ]
[140] x°P@@F
Gh
½ÃRZ%H³å¥ FD)³f~DÐ᱿a &@t*!eTb´8¼)%<Ò7td*Þ¦Ñ/²h ÈvPRåA|D*M§iìÍaZ]þEì°Z&I$Æ.Ép AÔk«)Ũ LÔ^¦h$ɶ)æPy˺¢4!§jTñ”.e5r1Eînf0p, 252140174 byte, [ … ] [141] ³å¥ FD)³f~DÐ᱿a &@t*!eTb´8¼)%<Ò7td*Þ¦Ñ/²h ÈvPRåA|D*M§iìÍaZ]þEì°Z&I$Æ.Ép AÔk«)Ũ LÔ^¦h$ɶ)æPy˺¢4!§jTñ”.e5r1Eînf0p, -1670118336 byte, [ … ] [142] eTb´8¼)%<Ò7td*Þ¦Ñ/²h ÈvPRåA|D*M§iìÍaZ]þEì°Z&I$Æ.Ép AÔk«)Ũ LÔ^¦h$ɶ)æPy˺¢4!§jTñ”.e5r1Eînf0p, -1498554838 byte, [ … ] [143] ÈvPRåA|D*M§iìÍaZ]þEì°Z&I$Æ.Ép AÔk«)Ũ LÔ^¦h$ɶ)æPy˺¢4!§jTñ”.e5r1Eînf0p, -2087034603 byte, [ … ] [144] ì°Z&I$Æ.Ép AÔk«)Ũ LÔ^¦h$ɶ)æPy˺¢4!§jTñ”.e5r1Eînf0p, -736951139 byte, [ … ] [145] Ũ LÔ^¦h$ɶ)æPy˺¢4!§jTñ”.e5r1Eînf0p, 2035344898 byte, [ … ] [146] 4!§jTñ”.e5r1Eînf0p, 472933998 byte, [ … ] [147] AíhòvRMX#IØ«T<Mð,à.ÍÊ¥)Rj”í£¤¬4±ÃêE1(DB2nÅö©hGÁÃ]¢4ãÑ06h8ÿoD$ìLY^[W<ÇíbêÏ
0¥¿ÍÚAë= ¡LÊ6õ
@(ç²h%8,C5ê«Òz Õ×J(eõ÷0-êí,H!jeU<!ت¡A-pAb@¬peàQW !!úE[
Da *À@
xºå!#zÊZ
+Á, 529836929 byte, [ … ]
[148] ,à.ÍÊ¥)Rj”í£¤¬4±ÃêE1(DB2nÅö©hGÁÃ]¢4ãÑ06h8ÿoD$ìLY[1]
[226] , 536885608 byte, [ … ]
[227] 89, 2 byte, [?]
[228] , 536885408 byte, [ … ]
[229] s, 1 byte, [(null)]
[230] , 85844 byte, [ … ]
[231] , 0 byte, [(null)]
[232] , 414 byte, [ … ]
[233] , 536879612 byte, [ … ]
[234] X, 66115 byte, [ … ]
[235] , 536871000 byte, [ … ]
[236] Ì, 536871852 byte, [ … ]
[237] sÏ, 536885768 byte, [ … ]
[238] , -1845731310 byte, [ … ]
[239] (, -1622764740 byte, [ … ]
[240] cáÒ ä ~KM¢, 0 byte,
W<ÇíbêÏ
0¥¿ÍÚAë= ¡LÊ6õ @(ç²h%8,C5ê«Òz Õ×J(eõ÷0-êí,H!jeU<!ت¡A-pAb@¬peàQW !!úE[ Da *À@ xºå!#zÊZ +Á, -1623979092 byte, [ … ] [149] E1(DB2nÅö©hGÁÃ]¢4ãÑ06h8ÿoD$ìLY^[W<ÇíbêÏ
0¥¿ÍÚAë= ¡LÊ6õ
Da *À@
xºå!#zÊZ
+Á, 279076291 byte, [ … ]
[150] 6h8ÿoD$ìLY[1].2ÕDÉDKË@Üá6’a(Δ&Á1ðf>i»¤ÜòÊx#Zjj¤B5s/ö”PÁ¥¡2<vÂ, 639815208 byte, [ … ]
[200] 1ðf>i»¤ÜòÊx#Zjj¤B5s/ö”PÁ¥¡2<vÂ, -2106955174 byte, [ … ]
[201] s/ö”PÁ¥¡2<vÂ, -2005638125 byte, [ … ]
[202] äj
$_oHD1Y§&%%5 /lðÓì|h.a, -1607129819 byte, [ … ] [203]
ðÓì|h.a, -1283112444 byte, [ … ]
[204] P÷Щ F07VÂiû D, 957677636 byte, [ … ]
[205] 2H8Ï¢Iv, -888269598 byte, [ … ]
[206] Kï Y0þëï£w5¯ê@X«”Òü?$¨3¶DAô”È SøÄlÂë8I¡ÉûN ÌYJjN¤õp¢mbDɤ5lÐC3³°@¢J¹H2”hÁtäÆ$FÄXF, -2128804520 byte, [ … ]
[207] ü?$¨3¶DAô”È SøÄlÂë8I¡ÉûN ÌYJjN¤õp¢mbDɤ5lÐC3³°@¢J¹H2”hÁtäÆ$FÄXF, 525539337 byte, [ … ]
[208] Âë8I¡ÉûN ÌYJjN¤õp¢mbDɤ5lÐC3³°@¢J¹H2”hÁtäÆ$FÄXF, 1779911257 byte, [ … ]
[209] õp¢mbDɤ5lÐC3³°@¢J¹H2”hÁtäÆ$FÄXF, 1251254848 byte, [ … ]
[210] “hÁtäÆ$FÄXF, 68805381 byte, [ … ]
[211] .enH8]qb@ÄýÆ©klͦ£X’ÕeHc:ºÅâÉHraPðø°Ù, 1795954579 byte, [ … ]
[212] ¦£X’ÕeHc:ºÅâÉHraPðø°Ù, 90279174 byte, [ … ]
[213] °Ù, -1035808564 byte, [ … ]
[214] <Yh{DËðGËÉ 8 , 294921 byte, [ … ]
[215] , 2016256240 byte, [ … ]
[216] .Q3úH5Dà”i& RrÉ&i<
GKÄstî, -1966509539 byte, [ … ]
[217]
GKÄstî, 406 byte, [ … ]
[218] i, 1663 byte, [ … ]
[219] , 536871852 byte, [ … ]
[220] , 10485760 byte, [ … ]
[221] ùÿÿÿ, -1610612736 byte, [ … ]
[222] , 1 byte, [A]
[223] X, 536885664 byte, [ … ]
[224] , 0 byte, [ :]
[225] G, ↩︎
