Hi.
I use Mbed compiler and Wizwiki-W7500p with LAN-connection to my notebook (192.168.0.3).
I can compile ECHO-server example (set IP 192.168.0.50 for server W7500p), use program (TCP client), connect notebook with server, send data from PC, recieve answer.
It is work correctly, Im happy)).
Now I want to configure the WIZ-board as a client, and the laptop as a server: the board will initiate a connection to the laptop, send a data packet, the server-client (in PC) will display this packet, and send something in response.
Where I can found example of CLIENT for W7500p?
CODE for web-server (control LEDs via ethernet):
int main (void)
myledR=myledG=myledB=1;
mGND=0;
myledR=0;
step.attach(&TMR, 1);
puart.attach(&rx_interruptUART, Serial::RxIrq);
//=============================================START=============================
printstr(sss, sprintf (sss, " ZEZMANs Programm is starting...\r\n"));
wait(1);
myledG=0;
EthernetInterface eth;
eth.init(mac_addr, ip_addr, subnet_mask, gateway_addr);
eth.connect();
wait(0.1);
printstr(sss, sprintf (sss, "Server IP Address is %s\r\n", eth.getIPAddress()));
wait(0.1);
if (*(volatile uint32_t *)(W7500x_WZTOE_BASE+SIPR)==0) NVIC_SystemReset();
myledG=0;
TCPSocketServer server;
server.bind(ECHO_SERVER_PORT);
server.listen();
while (true) {
printstr(sss, sprintf (sss, "Wait for new connection...\r\n"));
TCPSocketConnection client;
printstr(sss, sprintf (sss, "TCPSocketConnection client complete\r\n"));
client.set_blocking(false, 250); // Timeout after (15)s
TCPSS_tmr=250;
TCPSS_blk=true;
while(1) {
if ((tmrT&0x1)==1) {
myledB=0;
} else {
myledB=1;
if (!server.accept(client)) break;
//================CONNECT==================================
client.set_blocking(false, 15000); // Timeout after (15)s
printstr(sss, sprintf (sss, "Connection from: %s\r\n", client.get_address()));
tmrT=0;
wait(0.1);
char webt[]= {'P','I','N','G','_','O','N',0x0d,0x0a};
while (true)
int n = client.receive(buffer, sizeof(buffer));
if (n <= 0) break;
// print received message to terminal
buffer[n] = '\0';
printf("Received message from Client :'%s'\r\n",buffer);
if (buffer[0]==0x31)
myledG=0;
char web[]= {'L','E','D','_','G','_','O','N',0x0d,0x0a};
client.send_all(web,sizeof web);
if (buffer[0]==0x32)
myledG=1;
char web[]= {'L','E','D','_','G','_','O','F','F',0x0d,0x0a};
if (buffer[0]==0x33)
myledR=0;
char web[]= {'L','E','D','_','R','_','O','N',0x0d,0x0a};
if (buffer[0]==0x34)
myledR=1;
char web[]= {'L','E','D','_','R','_','O','F','F',0x0d,0x0a};
if (buffer[0]==0x35)
myledB=0;
char web[]= {'L','E','D','_','B','_','O','N',0x0d,0x0a};
if (buffer[0]==0x36)
myledB=1;
char web[]= {'L','E','D','_','B','_','O','F','F',0x0d,0x0a};
client.close();
Please show how will look program for a client that initiates a connection to 192.168.0.3:80 and sends a packet “12345678” to the server (which the program emulates on a PC)
