[quote=“randomizer”]could you please share your code for sending and receiving data to/from the PC?[/quote]
void W5500_Write_TXBuf(unsigned char SocketNr, unsigned char *z, unsigned int len)
unsigned char /z[] =“Hallo ich bin da, wer noch?”,/ i, AdrHi, AdrLo;
unsigned int Adr;
// z[0]=169; z[1]=254;z[2]=101;z[3]=2;z[4]=0x13;z[5]=0x88;z[6]=0;z[7]=10;
TIMER_START(74);
#ifdef SEND_BLOCK
// (<- BSB ->|<- nR/W ->|<- OP ->, ADRHI, ADRLO)
//SPI_Block(CNTRL_Sn(Nr) | CNTRL_TXBUF | CNTRL_WRITE | CNTRL_VDM, AdrHi, AdrLo); // ControlByte
// 13 + Rec BYTES
SPI_Block(SocketNr);
//SPI_BLOCK_MAC(AdrHi, AdrLo, CNTRL_Sn(Nr) | CNTRL_TXBUF | CNTRL_WRITE | CNTRL_VDM);
#else
// Page 56/65 (WizChip Datasheet 1.0):
// Sn_TX_WR
// 1. READ THE STARTING...(aka Sn_TX_RD):
// Lies Pointer (wohin Daten im Buffer?)
// 5 BYTES
GPO_ptr[3] = 0x00 | FREQ_BIT | CS_BIT ; // Freq & nCS
SPI_Byte(0x00); // 1. AdrByte
SPI_Byte(0x22); // 2. AdrByte
// (<- BSB ->|<- nR/W ->|<- OP ->)
SPI_Byte(CNTRL_Sn(SocketNr) | CNTRL_REG | CNTRL_READ | CNTRL_VDM); // ControlByte
AdrHi = SPI_Byte(0xFF); // DummyByte for Read
AdrLo = SPI_Byte(0xFF); // DummyByte for Read
GPO_ptr[3] = 0x00 | FREQ_BIT ; // Freq
// 2. SAVE THE TRANSMITTING.. (write to Buffer starting @Adr
// Schreiben von Sn_TX_RD
// 3 BYTES + Rec
SPI_Byte(AdrHi); // 1. AdrByte
SPI_Byte(AdrLo); // 2. AdrByte
SPI_Byte(CNTRL_Sn(SocketNr) | CNTRL_TXBUF | CNTRL_WRITE | CNTRL_VDM); // ControlByte
Adr = (AdrHi<<8) | AdrLo;
#ifdef DEBUG
xil_printf(“Sn_TX_WR: Adr = 0x%x %x %x\n\r”, Adr, AdrHi, AdrLo);
#endif
i=0;
while(i<len)
#ifdef DEBUG
xil_printf(" TX-S%d Byte %d 0x%x = 0x%x %d %c\n\r", 0, i, i, z[i], z[i], z[i]);
#endif
SPI_Byte(z[i++]);
Adr++;
AdrHi = (Adr & 0xFF00)>>8;
AdrLo = (Adr & 0x00FF) ;
// 3. AFTER SAVING... (update Sn_TX_WR to ADR)
// Schreiben von Sn_TX_WR
// 5 BYTES
SPI_Byte(0x24); // 2. AdrByte
SPI_Byte(CNTRL_Sn(SocketNr) | CNTRL_REG | CNTRL_WRITE | CNTRL_VDM); // ControlByte
#ifdef DEBUG
#endif
#endif
TIMER_STOPP(74);
void W5500_Send_TXBuf(unsigned char SocketNr)
W5500_SocketCmd(SocketNr, 0x20);
void W5500_SocketCmd(unsigned char SocketNr, unsigned char Cmd)
// 4. Socket 0, SEND:
// 4 BYTES
SPI_Byte(0x01); // 2. AdrByte
SPI_Byte(Cmd);
void W5500_Read_TXBuf(unsigned char SocketNr)
// Nur 10 Byte lesen…
unsigned char z,/z[] =“Hallo ich bin da, wer noch?”,/ i, AdrHi, AdrLo;
unsigned int Adr;
Adr = (AdrHi<<8) + AdrLo;
Adr = Adr - 10;
SPI_Byte(CNTRL_Sn(SocketNr) | CNTRL_TXBUF | CNTRL_READ | CNTRL_VDM); // ControlByte
i=0;
while(i<10)
z = SPI_Byte(0xFF);
xil_printf(" TX-S%d Byte %d 0x%x = 0x%x %d %c\n\r", 0, i, i, z, z, z);
i++;
void W5500_Read_RXBuf(unsigned char SocketNr)
unsigned int i, Adr, Len;
unsigned char z, AdrHi, AdrLo, LenHi, LenLo;
// Lies Start-Adresse (wo beginnen Daten im Buffer?)
// 7 BYTES
SPI_Byte(0x26); // 2. AdrByte
LenHi = SPI_Byte(0xFF); // Anzahl 0x26
LenLo = SPI_Byte(0xFF); // 0x27
AdrHi = SPI_Byte(0xFF); // Adr1 0x28
AdrLo = SPI_Byte(0xFF); // Adr2 0x29
Len = (LenHi<<8) + LenLo; //
Adr = (AdrHi<<8) + AdrLo; //
#ifdef DEBUG
xil_printf(“Adr = 0x%x %x %x\n\rLen = %d %x %x\n\r”, Adr, AdrHi, AdrLo, Len, LenHi, LenLo);
#endif
// Auslesen von RX-Buffer von Socket SockNr, ab Adresse Adr, Anzahl Len:
// 3 + LEN
SPI_Byte(CNTRL_Sn(SocketNr) | CNTRL_RXBUF | CNTRL_READ | CNTRL_VDM); // ControlByte
for(i=0; i < Len; i++)
z = SPI_Byte(0xFF); // DummyByte for Read
xil_printf(" RX-S%d Byte %d 0x%x = 0x%x %d %c 0x%x\n\r", 0, i, i, z, z, z, Adr+i);
if(i==7) xil_printf("\n\r");
// Start-Adresse updaten (Adr = Adr + Len)
// 5 BYTES
Adr = Adr + Len;
SPI_Byte(0x28); // 2. AdrByte
// RECV-Command !
// 4 BYTES
SPI_Byte(0x40); // RECV
// In Summe: 7 + 3 + LEN + 5 + 4 == 19 + LEN BYTES
