github.com/Wiznet/W7500P/issues/3
This code : github.com/Wiznet/W7500P/blob/m … t/socket.c
ctlsocket() and getsockopt() were seriously broken without the ‘break;’ statements.
Hope you patch this soon and also check other versions of this code…
I can not understand how these kind of errors can go unnoticed for so long, no peer review?
Good luck,
Edwin van den Oetelaar
diff -r e377caf76636 W7500P/W7500P_FW/ioLibrary/Ethernet/socket.c
--- a/W7500P/W7500P_FW/ioLibrary/Ethernet/socket.c Tue Apr 05 21:28:05 2016 +0200
+++ b/W7500P/W7500P_FW/ioLibrary/Ethernet/socket.c Sun Apr 10 17:20:23 2016 +0200
@@ -52,12 +52,12 @@
#include "socket.h"
#include "W7500x_wztoe.h"
-#define SOCK_ANY_PORT_NUM 0xC000;
+#define SOCK_ANY_PORT_NUM (0xC000)
static uint16_t sock_any_port = SOCK_ANY_PORT_NUM;
static uint16_t sock_io_mode = 0;
static uint16_t sock_is_sending = 0;
-static uint16_t sock_remained_size[_WIZCHIP_SOCK_NUM_] = {0,0,};
+static uint16_t sock_remained_size[_WIZCHIP_SOCK_NUM_] = {0,};
static uint8_t sock_pack_info[_WIZCHIP_SOCK_NUM_] = {0,};
#if _WIZCHIP_ == 5200
@@ -589,6 +589,7 @@ int8_t ctlsocket(uint8_t sn, ctlsock_ty
break;
case CS_GET_INTMASK:
*((uint8_t*)arg) = getSn_IMR(sn);
+ break;
default:
return SOCKERR_ARG;
@@ -664,6 +665,7 @@ int8_t getsockopt(uint8_t sn, sockopt_t
break;
case SO_MSS:
*(uint8_t*) arg = getSn_MSSR(sn);
+ break;
case SO_DESTIP:
getSn_DIPR(sn, (uint8_t*)arg);
break;
@@ -678,8 +680,10 @@ int8_t getsockopt(uint8_t sn, sockopt_t
#endif
case SO_SENDBUF:
*(uint16_t*) arg = getSn_TX_FSR(sn);
+ break;
case SO_RECVBUF:
*(uint16_t*) arg = getSn_RX_RSR(sn);
+ break;
case SO_STATUS:
*(uint8_t*) arg = getSn_SR(sn);
break;
