I have a problem with a W5500 based system, using the latest Wiznet lib from github.
I have a server running on an STM32F103C8T8 board, and checking the incoming requests. When a client requests is received, it is served, only one request at a time.
The requested HTML page, loaded from an SD card, has 4 images asserted.
The client (browser) request the HTML page and before it is loaded completely, the asserted four images are also requested in parallel.
However, it seems that the request for the forth (last) image is rejected by the W5500 chip, the browser receives “ERR_CONNECTION_REFUSED”.
Attached the client (Google Chrome) network log:
[I cannot attach a picture (68kB JPG), “HTTP error” message is shown…]
Also see here: stm32duino.com/viewtopic.php?f=9 … 011#p22011
and the server log:
urrent date and time: 17-01-06 11:40:32
---> request from: 192.168.100.51
--- Socket status ---
Socket 0 is ESTABLISHED, port: 80, D: 192.168.100.51(58303), RX: 420
Socket 1 is LISTEN, port: 80, D: 192.168.100.1(123), RX: 0
Socket 2 is CLOSED, port: 80, D: 192.168.100.51(57950), RX: 0
Socket 3 is CLOSED, port: 80, D: 192.168.100.51(58096), RX: 0
GET /web/index.htm HTTP/1.1
Checking request: web/index.htm
...processed in: 258
Socket 0 is ESTABLISHED, port: 80, D: 192.168.100.51(58303), RX: 0
Socket 1 is ESTABLISHED, port: 80, D: 192.168.100.51(58304), RX: 371
<--- client end.
Current date and time: 17-01-06 11:40:32
Socket 0 is SYNRECV, port: 80, D: 192.168.100.51(58305), RX: 0
GET /web/img/backgrnd.png HTTP/1.1
Checking request: web/img/backgrnd.png
...processed in: 596
Socket 0 is ESTABLISHED, port: 80, D: 192.168.100.51(58305), RX: 370
Socket 1 is ESTABLISHED, port: 80, D: 192.168.100.51(58304), RX: 0
<--- client end.
Current date and time: 17-01-06 11:40:33
Socket 1 is LISTEN, port: 80, D: 192.168.100.51(58304), RX: 0
GET /web/img/pump-on.png HTTP/1.1
Checking request: web/img/pump-on.png
...processed in: 34
Socket 0 is ESTABLISHED, port: 80, D: 192.168.100.51(58305), RX: 0
<--- client end.
Socket 0 is LISTEN, port: 80, D: 192.168.100.51(58305), RX: 0
Socket 1 is ESTABLISHED, port: 80, D: 192.168.100.51(58306), RX: 365
GET /web/img/ww.png HTTP/1.1
Checking request: web/img/ww.png
...processed in: 27
Socket 1 is ESTABLISHED, port: 80, D: 192.168.100.51(58306), RX: 0
<--- client end.
As one can see, the requests are handled consecutively by the server, but the request for the last image (compress.png) seems to be rejected by the W5500 hardware before is transmitted to the server software.
Can someone give a hint what am I missing?
Or it is a well known limitation of the W5500 chip to be able to receive only up to 4 parallel request from the same client?
