I need to help with application, where I used module with WIZNET W5500 chip. I using chip as webserver, now I need to send response to http querry (for example image). Unfortunately, buffer of chip is max 32KB, that is maximum size for Tx_buffer if I use all internal memory as TX_buffer for one SOCKET, but I need to send bigger data.
In other applications, file is split to smaller blocks and send as TCP segments (reasembled psů in wireshark). How I can do that with W5500? I try to find answer on web, but without success.
Do you have any tutorials for webserver with W5500?
Thanks for your help.
