I am unable Write to the buffer until i change the command register to the send.
here is my code:
void readflash(uint32_t addr, uint16_t size){
uint16_t v,j,k, len, pointer;
j = size/256;
len = size - (j * 256);
if (j > 0){
for(v = 0; v < j; v++){
SerialFlash_ReadArray(addr, &read, 256);
addr = addr + 0x000100;
wiz_send_data(SOCK_WEBSERVER, read, 256);
Delay_ms(10);
if(len > 0){
SerialFlash_ReadArray(addr, &read, len);
wiz_send_data(SOCK_WEBSERVER, read, len);
Delay_ms(10);
else{
SerialFlash_ReadArray(addr, &read, size);
wiz_send_data(SOCK_WEBSERVER, *read, size);
While i am trying to write the 1381 bytes and change the command register to send. i am seeing only a packet of length 101 which is the last set i am writing the to the TX Buffer.
