pherig
February 8, 2017, 7:40pm
#1
Dear,
Is it possible to use pin PB_06 as a Digital GPO?
In the w7500p reference manual, I found dubious information regarding this topic:
Table 10 states that its alternate function is a GPIO port
Section 12.4.20 states it has no alternate function
I have also performed some tests, however I didn’t manage to set pin PB_06 as a Digital GPO pin.
Any help is appreciated
Hello, pherig
Yes!
The pin PB_06 is possible to be used as GPIO too.
And it is so sorry to guide confused documents.
We will correct as soon as possible.
Thank you so much,
lawrence
AMWJ
January 25, 2018, 3:57pm
#3
Greetings,
are you using the default libraries? Maybe the following code will help you, let me know if it works for you.
GPIO_InitDef.GPIO_Pin = GPIO_Pin_6;
GPIO_InitDef.GPIO_Mode = GPIO_Mode_OUT; // Set to Mode Output
GPIO_Init(GPIOB, &GPIO_InitDef);
PAD_AFConfig(PAD_PB, GPIO_Pin_6, PAD_AF1);
nda
September 12, 2018, 8:44am
#4
PB_06 doesnot work as GPIO!!! According to the table 10 in section 12.3 of W7500P Reference Manual
Version 1.0.3 it has such function, but according to 15.6.2 it doesnot have such function. I’ve tried. It doesnot work!
hello nda
sorry for late reply.
the new w7500x datasheet said that PB_6 does not work as GPIO anymore in table 4 (only dup)
please refer the below link
thank you
leejin0
October 23, 2018, 6:15am
#6
I am very confused. because I am using PB06 of W7500p as GPIO now.
Of course, the datasheets were shown to be available only as DUP, but I ignored that.
And I’ve written code that toggles the pin every 0.5 seconds.
And it works well.
