Could you review our schematic, it is not working?
Please find link
https://we.tl/t-bEEc7Efkrh
Please find link
Dear Nagarajan_V
Everything is not it working?
My opinion is,
You must remove the R96, R97, R98, R99.
RJ45 GND and system GND should be separated by using a high-voltage capacitor.
Thank you
Thank you for kind reply.
We have already removed R96, R97, R98 and R99.
I did not see any pulses on PA_02 pin. Crystal oscillations are OK.
Reset and boot levels are OK , Any other point need to check?
Dear Nagarajan-V
You sure you’ve done the work of the internal MCU?
EX) firmware download…
In my opinion, if the crystal is work, it seems normal.
However, if the network does not work, the PCB design should be considered.
You have to tell me specifically what the problem.
Dear Scott
Thanks for your reply.
We use preprogrammed W7500P with S2E firmware.
Green LED is on and Activity Indicator is Blinking on RJ45 connector but search through Config Tool, device is not listed.
No response for commands from RS232 side.
No debug message is also outputted.
Dear Nagarajan_V
If so, I think your W7500P seems to be working properly hardware.
Debug messages are output to UART2. Did you check it?
Except for this, your schematic is fine.
Scott
Dear Scott
Thanks your verification of our circuit
Debug message is not output.
What else can be tested.
V.Nagarajan
Dear Scott
Can you share gerber of wiz750sr-RS232 module.
What is reset time required for the module.
V.Nagarajan
