Hi all,
I am facing a problem regarding the flash memory. With the following code, I can write the data and read it. However, if I disable DO_IAP(IAP_ERAS_DAT0,0,0,0) and DO_IAP(IAP_PROG,DAT0_START_ADDR,save_buff,SECT_SIZE) and try to read the data that I wrote previously, I will get strange results (no consistent values). This code is based on the IAP_EXAMPLE, in the library. What am I doing wrong?
#include "W7500x.h"
#include "mbed.h"
#define IAP_ENTRY 0x1FFF1001
#define IAP_ERAS 0x010
#define IAP_ERAS_DAT0 (IAP_ERAS + 0)
#define IAP_ERAS_SECT (IAP_ERAS + 2)
#define IAP_ERAS_BLCK (IAP_ERAS + 3)
#define IAP_ERAS_CHIP (IAP_ERAS + 4)
#define IAP_ERAS_MASS (IAP_ERAS + 5)
#define IAP_PROG 0x022
#define DAT0_START_ADDR 0x0003FE00
#define BLOCK_SIZE 4096
#define SECT_SIZE 256
struct data{
char something1[5];
int something2;
} test;
void DO_IAP( uint32_t id, uint32_t dst_addr, uint8_t* src_addr, uint32_t size);
int main()
strcpy(&test.something1[0] ,"abcd");
test.something2 = 1000;
uint8_t save_buff[BLOCK_SIZE];
memcpy(save_buff, (const char*)&test, sizeof(data) );
DO_IAP(IAP_ERAS_DAT0,0,0,0);
DO_IAP(IAP_PROG,DAT0_START_ADDR,save_buff,SECT_SIZE);
uint8_t data_save[BLOCK_SIZE];
memcpy(data_save,(uint8_t *)(DAT0_START_ADDR),sizeof(data));
data *p = (data*)data_save;
printf("Something1: %s, Something2: %d \r\n",p->something1, p->something2);
uint32_t temp_interrupt;
// Backup Interrupt Set Pending Register
temp_interrupt = (NVIC->ISPR[0]);
(NVIC->ISPR[0]) = (uint32_t)0xFFFFFFFF;
// Call IAP Function
((void(*)(uint32_t,uint32_t,uint8_t*,uint32_t))IAP_ENTRY)( id,dst_addr,src_addr,size);
// Restore Interrupt Set Pending Register
(NVIC->ISPR[0]) = temp_interrupt;
Thanks!
