Hello, I’m desenvovendo equipment for marking times from as entry and exit of employee, it used a module WIZ110SR, our problem precisely in this reading IP, port, and other parameters for the serial.
When we send <+ + +> only got a response from the module after sending a Reset command, thus the command <+ + +> .
This correct this operation?
Below step is correct.
+++ ← Enter the serial command mode.
← Print the IP address.
← Leave the serial command mode.
Serial configuration option is enabled before using the serial command mode.
Serial configuration option is in the Option tab of Configuration Tool.
Thank ywkwon,
Just seems odd, since the module only returns information after receiving the command, and it always takes 12 seconds to respond, received after 12 seconds comes the answer to the command or set of commands sent to the module.
I’m working with version 4.31 of the module Wiz110SR.
