안녕하세요?
말씀하신데로… AT+WAUTH=1로 했지만… 증상은 똑같습니다…ㅠㅠ
그리고
제가 팩토리 리셋( AT&F를 사용)
한후
다시 켰는데…
켜자마자… 아래와 같은 [ERROR]이 뜹니다…
그래서 일단 그건 신경 안쓰고 바로 다음의 명령들을 넣어보았습니다.
2017-11-29 09:19:45.518 [RX] -
[ERROR] <===============켜자마자 생기는 ERROR…
2017-11-29 09:19:55.371 [TX] - AT+WD
2017-11-29 09:19:55.386 [RX] - AT+WD
[OK]
2017-11-29 09:19:56.291 [TX] - AT+XDUM=0
2017-11-29 09:19:56.307 [RX] - AT+XDUM=0
[OK]
2017-11-29 09:19:57.228 [TX] - AT+WM=2
2017-11-29 09:19:57.243 [RX] - AT+WM=2
[OK]
2017-11-29 09:19:58.116 [TX] - AT+WAUTH=1
2017-11-29 09:19:58.132 [RX] - AT+WAUTH=1
[OK]
2017-11-29 09:19:59.723 [TX] - AT+WWEP1=1234567890
2017-11-29 09:19:59.739 [RX] - AT+WWEP1=1234567890
[OK]
2017-11-29 09:20:00.846 [TX] - AT+NDHCP=0
2017-11-29 09:20:00.862 [RX] - AT+NDHCP=0
[OK]
2017-11-29 09:20:01.752 [TX] - AT+NSET=192.168.10.1,255.255.255.0,192.168.10.1
2017-11-29 09:20:01.767 [RX] - AT+NSET=192.168.10.1,255.255.255.0,192.168.10.1
[OK]
2017-11-29 09:20:02.811 [TX] - AT+DHCPSRVR=1
2017-11-29 09:20:02.828 [RX] - AT+DHCPSRVR=1
[OK]
2017-11-29 09:20:04.606 [TX] - AT+WA=LimitedAP,8,
2017-11-29 09:20:04.622 [RX] - AT+WA=LimitedAP,8,
IP SubNet Gateway
192.168.10.1: 255.255.255.0: 192.168.10.1
[OK]
2017-11-29 09:20:07.586 [TX] - AT+XAR=5
2017-11-29 09:20:07.601 [RX] - AT+XAR=5
[OK]
2017-11-29 09:20:08.552 [TX] - AT+PSPOLLINTRL=1
2017-11-29 09:20:08.568 [RX] - AT+PSPOLLINTRL=1
[OK]
2017-11-29 09:20:10.893 [TX] - AT+NAUTO=1,1,5000
2017-11-29 09:20:10.909 [RX] - AT+NAUTO=1,1,5000
[OK]
2017-11-29 09:20:11.923 [TX] - AT&W0
2017-11-29 09:20:11.938 [RX] - AT&W0
[OK]
2017-11-29 09:20:13.015 [TX] - AT&Y0
2017-11-29 09:20:13.030 [RX] - AT&Y0
[OK]
위의 명령들을 넣고 난후
다시 전원을 OFF했다가 ON아니까
이번엔
Serial2WiFi APP-Ext.PA (WIZnet Co.Lte) 라는 메세지가 뜨고
다시 바로… [ERROR]이 나더니…
아래와 같은 이상한것들이 무한반복해서 나타납니다…ㅠㅠ
2017-11-29 09:20:52.947 [RX] - ????
Serial2WiFi APP-Ext.PA (WIZnet Co.Ltd)
[ERROR]
IP SubNet Gateway
0.0.0.0: 0.0.0.0: 0.0.0.0
APP Reset-APP SW Reset
[ERROR]
IP SubNet Gateway
[ERROR]
IP SubNet Gateway
[ERROR]
IP SubNet Gateway
[ERROR]
IP SubNet Gateway
[ERROR]
IP SubNet Gateway
[ERROR]
IP SubNet Gateway
[ERROR]
IP SubNet Gateway
[ERROR]
IP SubNet Gateway
[ERROR]
IP SubNet Gateway
[ERROR]
IP SubNet Gateway
[ERROR]
IP SubNet Gateway
[ERROR]
IP SubNet Gateway
[ERROR]
몇일째 이 이슈로 계속 고생이네요 ㅠㅠ…
도움 부탁드립니다~!
