Hello all,
I’m new to arm and wiznet chips. So far, I’ve written a quarter of my own W5500 library (not tidied, yet). I also ran the tcp server code which uses built-in library on Wiznet site. (I used to send and receive data via TCP protocol and it means my hw and chips are ok!)
Now… with my manual library;
- I can init W5500.
- I can configure and run it as TCP Server
- I can read and write internal registers
- I can see how many bytes received on Socket 0 correctly
- I can read and write rx buffer pointer correctly
But my problem is that I always read 0x00 from RX buffer on Socket 0.
Here is my part of code:
while(1){
if (W5500_REG_READ_BYTE(SOCKET0_REGISTER_BLOCK, Sn_SR) == SOCK_ESTABLISHED){
received_data_size = W5500_GET_RECEIVED_DATA_SIZE(); //WORKS
if((received_data_size) != 0){
rx_buff_data_pointer = W5500_GET_RECEIVED_DATA_POINTER();
for(int i = 0; i<2048; i++)
test_receive_buffer[i] = W5500_REG_READ_BYTE(SOCKET0_RX_BUFFER, i);
//ALWAYS RETURNS 0x00!
local_rx_buff_data_pointer += received_data_size;
W5500_REG_WRITE_BYTE(SOCKET0_REGISTER_BLOCK, Sn_RX_RD_MSB, 0);
W5500_REG_WRITE_BYTE(SOCKET0_REGISTER_BLOCK, Sn_RX_RD_LSB, local_rx_buff_data_pointer); //WORKS
W5500_REG_WRITE_BYTE(SOCKET0_REGISTER_BLOCK, Sn_CR, SOCKET_RECV); //WORKS
test_receive_buffer5 = W5500_REG_READ_BYTE(SOCKET0_REGISTER_BLOCK, Sn_SR); //EXTRA FUNCTION TEST WORKS
I also tried to read all 2048 bytes of data and saw nothing except a few foreign characters in the middle.
Here is my read byte function:
// READ BYTE FUNCTION
uint8_t W5500_REG_READ_BYTE(uint8_t r_W5500_REG_BLOCK, uint16_t r_W5500_REG_ADD){
uint8_t r_DataPhase;
uint8_t r_control_phase = (r_W5500_REG_BLOCK << 3) | (W5500_READ_FLAG << 2 ) | (W5500_OPERATION_MODE);
uint8_t r_reg_add_offset1 = (r_W5500_REG_ADD >> 8) & 0xFF;
uint8_t r_reg_add_offset2 = r_W5500_REG_ADD & 0xFF;
#if W5500_OPERATION_MODE == VARIABLE_DATA_LENGTH_MODE
HAL_GPIO_WritePin(SCSn_GPIO_Port, SCSn_Pin, GPIO_PIN_RESET);
if(((HAL_SPI_ERROR_STATE = HAL_SPI_Transmit(&W5500_SPI_PORT, &r_reg_add_offset1, sizeof(r_reg_add_offset1), W5500_SPI_TIMEOUT)) != HAL_SPI_ERROR_NONE)) goto W5500_REG_READ_BYTE_RET;
if(((HAL_SPI_ERROR_STATE = HAL_SPI_Transmit(&W5500_SPI_PORT, &r_reg_add_offset2, sizeof(r_reg_add_offset2), W5500_SPI_TIMEOUT)) != HAL_SPI_ERROR_NONE)) goto W5500_REG_READ_BYTE_RET;
if(((HAL_SPI_ERROR_STATE = HAL_SPI_Transmit(&W5500_SPI_PORT, &r_control_phase, sizeof(r_control_phase), W5500_SPI_TIMEOUT)) != HAL_SPI_ERROR_NONE)) goto W5500_REG_READ_BYTE_RET;
if(((HAL_SPI_ERROR_STATE = HAL_SPI_Receive(&W5500_SPI_PORT, &r_DataPhase, sizeof(uint8_t), W5500_SPI_TIMEOUT)) != HAL_SPI_ERROR_NONE)) goto W5500_REG_READ_BYTE_RET;
HAL_GPIO_WritePin(SCSn_GPIO_Port, SCSn_Pin, GPIO_PIN_SET);
#elif W5500_OPERATION_MODE == FIXED_1BYTE_DATA_LENGTH_MODE
#endif
return r_DataPhase;
W5500_REG_READ_BYTE_RET:
return HAL_SPI_ERROR_STATE;
This function works well with reading bytes of the chip. But I can not get any values except 0x00 from Rx buffer memory.
Any help will be welcomed…
Regards
Edit:
Here is detailed information…
1- Here, I’ve set received size and received pointer values as 5 for initial value (to see if it changes later)
2- Here, I connet to W5500 as TCP Client on port 5000
3- As expected, the initial value of the received data size changes to ‘0’ after establishing communication with W5500
![cr3](https://global.discourse-cdn.com/business5/uploads/wiznet/original/2X/9/98517a38ae84a5aad907ac7a3eb31f9f664164a2.png)
4- Then I send 4 bytes of “TEST” data from client.
5- Received size becomes ‘4’ and pointer value becomes ‘0’ as epected and no problem so far.
![cr4](https://global.discourse-cdn.com/business5/uploads/wiznet/original/2X/a/abbaaa555ebaf24b7903416b7a4ce8a449e63349.png)
6- Then I run this code:
for(uint16_t i = 0; i<20; i++)
7- Result is:
![cr6](https://global.discourse-cdn.com/business5/uploads/wiznet/original/2X/9/9d548ba8927a3e5c6086cad3e6b762242853860e.png)
8- After reading buffer, I check stock established register with the same read function and it works:
![cr5](https://global.discourse-cdn.com/business5/uploads/wiznet/original/2X/d/d1405dac1aa76070bc198e41b515353e2b9ff9b9.png)
Have you ever experienced something like this before?
