Hi, I am using WIZ811MJ, attached to FPGA in parallel mode. The initialization looks good, and module is replying to ping. However, whenever I’m trying to open a socket (UDP or TCP), there is no reaction to writing to Sx_CR, it does not get cleared and Sx_SR remains at 0.
I have checked quite few times the datasheet, but obviously I am still missing something.
Okay, the problem was in hardware - two of the address lines were swapped so that instead of writing to the command register it ended up in the buffer memory. Now the socket opens fine.
Hi, could you provide the source code please? I am working on something similar, but I am not receiving a response from the WIZ850io module when I try to read its version that should always be 0x04 (according to datasheet). I am not sure if my module is working because of this.
