I started to work on the evaluation board wiz5500WEB and I didn’t found any code that I can use to make it work as it was before I use my software, do you have the example code that the board comes with ? or any information that can help me, for example: when I want to communicate wiz 5500 via spi, there is an echo command that I can use to find out if the spi is working? More over about the pmode pins 1 2 3,If their state is 1 by default (hardware) this can work?
another question about wiz 5500 if i send command in spi i can see via prob with scope,the the wiz getting the command but always return zero , maybe the wiz isnt configured correctly? also i tried to get phy link and the same result ( no phy link)
As @irina_kim said, your SPI communication does not work (MISO must show 1-2-3 return bytes). Please explain the scope pictures above and tell us what are you trying to do.
Additionaly, my circuit devients from the recommended electronics scheme.
specifically,
Pin (22) 1V2O is connected with a 0.1uF capacitor instead of 10nF as suggested
Pin (20) TOCAP is connected with a 10uF capacitor instead of 4.7uF as suggested
Pins (30&31) XO & XI are both connected (with a crystal) to two 0.1uF capacitors, instead of 18pF
Can this affect the operation of the device?
(at the moment i have no control over the electronic part of this project)
I am trying to send a basic command which will will write a value to a specific register (GAR (Gateway IP Address Register) [R/W] [0x0001 – 0x0004] [0x00]), and then read this register to check that the write operation was successful.
the 4 0xFF are dummy bytes, to do the actual reading
So you mean that the MISO should responds with non NULL values while i’m in the middle of writing the actuall command?
does the device follows the rule of simply counting the bytes that it has received so far ?
Your misconfigured pins 20, 30 and 31 will of course affect the operation. You must comply to the values of the reference schematic, and read datasheet for connection guidelines.
Your W5500 simply can not operate properly because you have it wrongly connected.
