There is a serial command to turn off Wi-Fi?
Hi~~
As far as I know,Just turn off function is no using serial command with wifi.
but you can use “restart after factory reset function” of serial command.
If no, another person will reply about your question.
thanks,
I want in gateway-mode radio on/off via the serial interface!?
Hello Hardix
There is no command to turn off WiFi.
