Hi all,
I am using the MSP430F5529LP to connect with the wiz550io over SPI. Now I have the following problem. The wiz550io keeps sending the following bytes 0x01, 0x02, 0x03. see the picture
Not sure what is going on here. Even when i disconnected the MOSI pin and only let the MISO pin connected, it keeps sending 0x01, 0x02, 0x03.
I initialize the w5500 trough the following function:
uint8_t init_w5500(void)
uint8_t tmp;
uint8_t memsize[2][8] = { { 2, 2, 2, 2, 2, 2, 2, 2 },
{ 2, 2, 2, 2, 2, 2, 2, 2 } };
GPIO_setOutputHighOnPin(GPIO_PORT_P2, GPIO_PIN5);
GPIO_setAsOutputPin(GPIO_PORT_P2, GPIO_PIN5); // N_RESET
GPIO_setAsInputPinWithPullDownResistor(GPIO_PORT_P2, GPIO_PIN4);
GPIO_setOutputLowOnPin(GPIO_PORT_P2, GPIO_PIN5); // RESET Device
__delay_cycles(1000);
reg_wizchip_cs_cbfunc(wizchip_select, wizchip_deselect);
reg_wizchip_spi_cbfunc(wizchip_read, wizchip_write);
while(GPIO_getInputPinValue(GPIO_PORT_P2, GPIO_PIN4) == GPIO_INPUT_PIN_LOW);
/* wizchip initialize*/
if (ctlwizchip(CW_INIT_WIZCHIP, (void*) memsize) == -1) {
return STATUS_FAIL;
return STATUS_SUCCESS;
And then a function to set up the network
**uint8_t** **init_network** ( **void** )
/* wizchip netconf */
**if** ( **ctlnetwork** ( *CN_SET_NETINFO* , ( **void** *) &gWIZNETINFO) == -1){
**return** STATUS_FAIL;
**return** STATUS_SUCCESS;
SPI init & functions code can be found here below:
uint8_t init_spi(void)
//Set P2.7 for slave select
GPIO_setAsOutputPin(GPIO_PORT_P2, GPIO_PIN7);
//Set P2.7 high for slave deselect
GPIO_setOutputHighOnPin(GPIO_PORT_P2, GPIO_PIN7);
//P3.0,1,2 select for SPI configurations
GPIO_setAsPeripheralModuleFunctionInputPin(GPIO_PORT_P3, GPIO_PIN0 + GPIO_PIN1 + GPIO_PIN2);
//Initialize Master
USCI_B_SPI_initMasterParam param = {0};
param.selectClockSource = USCI_B_SPI_CLOCKSOURCE_SMCLK;
param.clockSourceFrequency = UCS_getSMCLK();
param.desiredSpiClock = SPICLK;
param.msbFirst = USCI_B_SPI_MSB_FIRST;
param.clockPhase = USCI_B_SPI_PHASE_DATA_CAPTURED_ONFIRST_CHANGED_ON_NEXT;
param.clockPolarity = USCI_B_SPI_CLOCKPOLARITY_INACTIVITY_LOW;
if(USCI_B_SPI_initMaster(USCI_B0_BASE, ¶m) != STATUS_SUCCESS){
return STATUS_FAIL;
//Enable SPI module
USCI_B_SPI_enable(USCI_B0_BASE);
// Enable USCI_B1 RX interrupt
USCI_B_SPI_clearInterrupt(USCI_B0_BASE, USCI_B_SPI_RECEIVE_INTERRUPT);
USCI_B_SPI_enableInterrupt(USCI_B0_BASE, USCI_B_SPI_RECEIVE_INTERRUPT);
//success
void wizchip_select ( void )
while (USCI_B_SPI_isBusy(USCI_B0_BASE));
GPIO_setOutputLowOnPin(GPIO_PORT_P2, GPIO_PIN7);
__delay_cycles(2);
voidwizchip_deselect(void)
while( USCI_B_SPI_isBusy(USCI_B0_BASE));
__delay_cycles(2);
uint8_t wizchip_read()
return USCI_B_SPI_receiveData** (USCI_B0_BASE);
void wizchip_write( uint8_t wb)
//USCI_B1 TX buffer ready?
while(! USCI_B_SPI_getInterruptStatus** (USCI_B1_BASE, USCI_B_SPI_TRANSMIT_INTERRUPT));
USCI_B_SPI_transmitData(USCI_B0_BASE, wb);
return;
I’m using the TCP server loopback function to test my set-up.
I hope someone can help me out.
Regards,
Caspar
