wk5000
1
Analog inputs 0 and 1 do not work.
Inputs 2 and 3 are ok.
Jumpers J27 und J28 are in the right position (temp and trimmer disabled)
Inputs 0 and 1 show fixed values, independent of any external voltage.
Op-Amp U8 seems to be dead?
Or is there any more way to configure Inputs 0 and 1?
Thanks
Hi~
I think you should test about A0,A1.
First, J27 and J28 are connect 1 and 2 with each other.
If Analog signal is correct operation at this situation, U8 seems to be dead.
wk5000
3
If I put J27 and J28 in the opposite position, trimmer and temp level are shown correctly.
Thus AD-Converter works, but U8 is dead
Unfortunately, you should be change an U8.
The Part name of U8 is LM358APWR(Dual Operational Amplifiers)
DataSheet Link : LM358APWR_Datasheet
