Hello
We are trying to give our board ethernet capabilites using w7500 chip. But our software only supports com port connectivity. Hence we can’t directly connect our board to our software over ethernet.
So we tried using WizVSP Software and it worked perfectly. But now we want to embed this software with our software in order to remove this extra software in between.
It would be helpful if somehow source code of the software can be made available to us. Or if you can tell some other way to convert tcp/ip data to com port data so that we can use it with existing software.
Thank You
