I created a PCB with the W5500 that supports POE. The W5500 works fine when it is powered externally, but it will not connect to the switch when it is powered using POE. I have verified that it is getting the proper 3.3 volts. Everything is based off of the reference schematic and the RJ45 jack I am using is the ARJP11B-MASA-B-A-EMU2. Are there any changes that should be made to the reference schematic when using POE?
I think It may be no problem RJ45(ARJP11B-MASA-B-A-EMU2) used.
What did you apply PoE(PD) module?
Could you please send us your schematic or datasheet for poe module?
If possible, I will check your schematic.
…Did you check FET(FQP30N06L) turn on status when PG signal is High?
I have checked your schematic. But I wasn’t able to find incorrect-point.
I think your schematic is fine.
