On the arduino platform, if you are not using the default GPIO of UART used by the Wizfi360 library, you need to change the definition of GPIO. There are two methods:
Method 1: Change the IO definition of the board. Taking wizfi360_evb_pico as an example, its IO configuration file is located at:
C:\Users\(uaername)\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\2.6.1\variants\wiznet_wizfi360_evb_pico\pins_arduino.h
You can change the GPIO definition of UART by changing the definition:
//Serial
// #define PIN_SERIAL1_TX (0u)
// #define PIN_SERIAL1_RX (1u)
#define PIN_SERIAL1_TX (4u)
#define PIN_SERIAL1_RX (5u)
This method is also suitable for W5100S_EVB_PICO. The changed file path is:
C:\Users\(uaername)\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\2.6.1\variants\wiznet_w5100s_evb_pico\pins_arduino.h
Method 2: Use the software serial port. If the IO used is not the GPIO of the hardware UART, you can only use the software serial port. You need to add the <SoftwareSerial.h> library.
And define GPIO through the following method,
SoftwareSerial SerialUart(3, 2); // IO3 for RX & IO2 for RX
SerialUart.begin(2000000);
WiFi.init(&SerialUart);
