I try to connect to the module but it seems not to be responding, my first idea after trying many other things, is that I am not on the same network and therefore the IP of the module is not what it should be, how could I know the IP of this if I am connecting through an Ethernet cable to an intermediate pcb card?
Hello, this is WIZnet Theo.
Please explain in detail the conditions under which you are trying to connect to the module. (For example, unable to connect to an S2E module operating as a server, unable to find the module in the config Tool, etc.)
You need to inform us which PCB card you are connecting in between.
