I mentioned this module last year in the general discussion forum but just updating the information as I have these in production and have also introduced a more compact mounting option that allows the module to mount flush to the motherboard and only requires pin headers to plug into.
The base module is based on the W5500 and is footprint compatible with the older W5200 based WIZ820io. The +P8 CPU module with microSD flush mounts to this to make a complete network server module with HTTP, FTP, TELNET along with SMTP, SNTP etc.
The “preliminary web datasheet is here”
New inverted vertical stack option for flush mounting.
