I have the following problem.
The AP to which I have to connect with the WizFi250 uses WPA2 AES with a key 32 hex numbers (64 digits) key, in command AT + WSEC modules accepts as hexadecimal key WPA key = 8 ~ 63 (ASCII) or 128 (HEX ).
Since 32 Hex numbers are 64-digit format what I have to pass in the command AT + WSEC ?
I tried to fill it with 0 (zero) before and after unsuccessfully …
Another question is on the network that is hidden, in AT + WSET I have to pass the BSID or just the SSID?
Thank You.
Hello Coccoliso
As you said below, WizFi250 can support only 128-hex-digit(64 byte).
Please refer to the below.
[quote]AT+WSEC=0,30313233343536373839303132333435363738393031323334353637383930313233343536373839303132333435363738393031323334353637383930313233
[OK]
AT+WSEC=?
0,30 31 32 33 34 35 36 37 38 39 30 31 32 33 34 35 36 37 38 39 30 31 32 33 34 35 36 37 38 39 30 31 32 33 34 35 36 37 38 39 30 31 32 33 34 35 36 37 38 39 30 31 32 33 34 35 36 37 38 39 30 31 32 33 [/quote]
