Hi, Eerik.
I’m employee of Wiznet.
If you want use spi mode ic(such as W5100, W5500), you have to connect your mcu specific spi code and iolibrary.
In this case, at least 4 spi functions registered. Chip select,deselect functions and spi byte read/write byte.
Ex)
There are some functions named “Your_MCU_SPI_Read_Byte()” and “Your_MCU_SPI_Write_Byte()”
You have to register your functions using “reg_wizchip_spi_cbfunc()” function in “wizchip_conf.c” like followings.
reg_wizchip_spi_cbfunc(Your_MCU_SPI_Read_Byte, Your_MCU_SPI_Write_Byte);
Initialize IC and Happy to use!
And WIZCHIP_IO_MODE_BUS is for bus mode ic(such as W5300).
