I’m sending the serial command '<WWwww.mysite.com> to the module, but the data are stored in the wrong way.
‘mysite.com’ is stored without ‘www.’.
I noticed that ‘www.’ is stored in the bytes reserved for DNS Server IP (I read 119.119.119.46 in the configuration tool software which are the ASCII codes for ‘www.’)
This error happens on firmwares greater than version 4.00.
Version 4.00 works correctly with the same command.
I’m doing something wrong? Can you check the problem.
Thank you
