I am using the Arduino UNOr3 and ArduIDE 1.6.4 and trying to compile the example code for Basic Server Test.
Using the Arduino WizFi shield.
WizFiShield Basic Server Test Example
This sketch makes the server socket and accpet TCP connection from the client
Circuit:
WizFiShield connected to Arduino via SPI
RST: pin 2 // Output
DRDY: pin 3 // Input
CSB: pin 4 // output
MOSI: pin 11 // output
MISO: pin 12 // input
SCK: pin 13 // out
Created 27 Sep. 2012
by James YS Kim (jameskim@wiznet.co.kr, javakys@gmail.com)
Modified 27 May. 2013
by Jinbuhm Kim (jbkim@wiznet.co.kr, jinbuhm.kim@gmail.com)
// WizFi210 communicates using SPI, so include the SPI library:
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <SPI.h>
#include <WizFi2x0.h>
#include <WizFiClient.h>
#include <WizFiServer.h>
#include <TimerOne.h>
#define SSID "borsuk" // SSID of your AP
#define Key "1234678901234567890123456" // Key or Passphrase
// Wi-Fi security option (NO_SECURITY, WEP_SECURITY, WPA_SECURITY, WPA2PSK_SECURITY)
#define Security WPA_SECURITY
unsigned int SrcPort = 50000; // listening port number
WizFi2x0Class myWizFi;
WizFiClient myClient[4];//(SIP, ServerPort);
WizFiServer myServer(SrcPort);
TimeoutClass ConnectInterval;
boolean Wifi_setup = false;
// 1msec Timer
void Timer1_ISR()
myWizFi.ReplyCheckTimer.CheckIsTimeout();
void setup() {
byte retval, i;
Serial.begin(9600);
Serial.println("\r\nSerial Init");
for(i=0; i<4; i++)
myClient[i] = WizFiClient();
myWizFi.begin();
ConnectInterval.init();
// Timer1 Initialize
Timer1.initialize(1000); // 1msec
Timer1.attachInterrupt(Timer1_ISR);
myWizFi.SendSync();
myWizFi.ReplyCheckTimer.TimerStart(3000);
Serial.println("Send Sync data");
while(1)
if(myWizFi.CheckSyncReply())
myWizFi.ReplyCheckTimer.TimerStop();
Serial.println("Rcvd Sync data");
break;
if(myWizFi.ReplyCheckTimer.GetIsTimeout())
Serial.println("Rcving Sync Timeout!!");
// Nothing to do forever;
for(;;)
// AP association
while(1)
byte tmpstr[32];
retval = myWizFi.associate(SSID, Key, Security, true);
if(retval == 1){
myWizFi.GetSrcIPAddr(tmpstr);
Serial.println("AP association Success");
Serial.print("MY IPAddress: ");
Serial.println((char *)tmpstr);
Wifi_setup = true;
break;
}else{
Serial.println("AP association Failed");
if(myServer.begin())
Serial.println("Server Listen OK");
else
Serial.println("Server Listen Failed");
void loop()
uint8_t i;
byte rcvdBuf[129];
memset(rcvdBuf, 0, 129);
if(Wifi_setup)
myWizFi.RcvPacket();
for(i=0; i<4; i++)
if(myClient[i].available()){
if(myClient[i].read(rcvdBuf))
Serial.print("CID[");
Serial.print((char)myClient[i].GetCID());
Serial.print("]");
Serial.println((char *)rcvdBuf);
myClient[i].write(rcvdBuf);
The progress is stuck here:
Build options changed, rebuilding all
Using library SPI in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI
Using library WizFiShield in folder: C:\Users\Damian\Documents\Arduino\libraries\WizFiShield (legacy)
Using library TimerOne in folder: C:\Users\Damian\Documents\Arduino\libraries\TimerOne (legacy)
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI -IC:\Users\Damian\Documents\Arduino\libraries\WizFiShield -IC:\Users\Damian\Documents\Arduino\libraries\TimerOne C:\Users\Damian\AppData\Local\Temp\build1556776878667064971.tmp\WizFiBasicServerTest.cpp -o C:\Users\Damian\AppData\Local\Temp\build1556776878667064971.tmp\WizFiBasicServerTest.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI -IC:\Users\Damian\Documents\Arduino\libraries\WizFiShield -IC:\Users\Damian\Documents\Arduino\libraries\TimerOne -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\utility C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\SPI.cpp -o C:\Users\Damian\AppData\Local\Temp\build1556776878667064971.tmp\SPI\SPI.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI -IC:\Users\Damian\Documents\Arduino\libraries\WizFiShield -IC:\Users\Damian\Documents\Arduino\libraries\TimerOne -IC:\Users\Damian\Documents\Arduino\libraries\WizFiShield\utility C:\Users\Damian\Documents\Arduino\libraries\WizFiShield\HTMLPages.cpp -o C:\Users\Damian\AppData\Local\Temp\build1556776878667064971.tmp\WizFiShield\HTMLPages.cpp.o
After I updated to IDE 1.6.5:
C:\Users\Damian\Documents\Arduino\libraries\WizFiShield\HTMLPages.cpp:5:1: error: 'prog_char' does not name a type
prog_char Protocol_Msg[] PROGMEM = "HTTP/1.1 200 OK\r\n"; // "String 0" etc are strings to store - change to suit.
C:\Users\Damian\Documents\Arduino\libraries\WizFiShield\HTMLPages.cpp:6:1: error: 'prog_char' does not name a type
prog_char Page1_Line0[] PROGMEM = "<!DOCTYPE html PUBLIC \"-//WAPFORUM//DTD XHTML Mobile 1.2//EN\" "; // "String 0" etc are strings to store - change to suit.
C:\Users\Damian\Documents\Arduino\libraries\WizFiShield\HTMLPages.cpp:7:1: error: 'prog_char' does not name a type
prog_char Page1_Line1[] PROGMEM = "\"http://www.wapforum.org/DTD/xhtml-mobile 12.dtd\">\r\n"; // "String 0" etc are strings to store - change to suit.
C:\Users\Damian\Documents\Arduino\libraries\WizFiShield\HTMLPages.cpp:8:1: error: 'prog_char' does not name a type
prog_char Html_start[] PROGMEM = "<html>\r\n"; // "String 0" etc are strings to store - change to suit.
C:\Users\Damian\Documents\Arduino\libraries\WizFiShield\HTMLPages.cpp:9:1: error: 'prog_char' does not name a type
prog_char head_start[] PROGMEM = "<head>\r\n"; // "String 0" etc are strings to store - change to suit.
C:\Users\Damian\Documents\Arduino\libraries\WizFiShield\HTMLPages.cpp:10:1: error: 'prog_char' does not name a type
prog_char Page1_Line2[] PROGMEM = "<meta http-equiv=\"Content-Type\" content=\"text/html/>\r\n";
C:\Users\Damian\Documents\Arduino\libraries\WizFiShield\HTMLPages.cpp:11:1: error: 'prog_char' does not name a type
prog_char Content_Msg[] PROGMEM = "Content-Type: text/html\r\n";
C:\Users\Damian\Documents\Arduino\libraries\WizFiShield\HTMLPages.cpp:12:1: error: 'prog_char' does not name a type
prog_char Page1_Line3[] PROGMEM = "<meta name=\"viewport\" content=\"user-scalable=no, initial-scale=5.0,";
C:\Users\Damian\Documents\Arduino\libraries\WizFiShield\HTMLPages.cpp:13:1: error: 'prog_char' does not name a type
prog_char Page1_Line4[] PROGMEM = " maximum-scale=5.0, minimum-scale=5.0, width=device-width\"/>\r\n";
C:\Users\Damian\Documents\Arduino\libraries\WizFiShield\HTMLPages.cpp:14:1: error: 'prog_char' does not name a type
prog_char head_end[] PROGMEM = "</head>\r\n"; // "String 0" etc are strings to store - change to suit.
C:\Users\Damian\Documents\Arduino\libraries\WizFiShield\HTMLPages.cpp:15:1: error: 'prog_char' does not name a type
prog_char Page1_Line5[] PROGMEM = "<body>\r\n";
C:\Users\Damian\Documents\Arduino\libraries\WizFiShield\HTMLPages.cpp:16:1: error: 'prog_char' does not name a type
prog_char new_Line[] PROGMEM = "\r\n";
C:\Users\Damian\Documents\Arduino\libraries\WizFiShield\HTMLPages.cpp:17:1: error: 'prog_char' does not name a type
prog_char Page1_Line6[] PROGMEM = "<h1 align=\"center\">Select </h1>\r\n";
C:\Users\Damian\Documents\Arduino\libraries\WizFiShield\HTMLPages.cpp:18:1: error: 'prog_char' does not name a type
prog_char Page1_Line7[] PROGMEM = "<form>\r\n";
C:\Users\Damian\Documents\Arduino\libraries\WizFiShield\HTMLPages.cpp:19:1: error: 'prog_char' does not name a type
prog_char Page1_Line8[] PROGMEM = "<table width=\"100%\"><tr><td colspan=3 align=\"center\"><h1>Press button you want</h1></td></tr><tr>";
C:\Users\Damian\Documents\Arduino\libraries\WizFiShield\HTMLPages.cpp:20:1: error: 'prog_char' does not name a type
prog_char Page1_Line8_cont[] PROGMEM = "<td width=\"40%\"></td><td width=\"20%\" bgcolor=\"silver\" align=\"center\"><h1><button ";
C:\Users\Damian\Documents\Arduino\libraries\WizFiShield\HTMLPages.cpp:21:1: error: 'prog_char' does not name a type
prog_char Page1_Line8_cont2[] PROGMEM = "name=\"command\" value=\"FW_CMD\">forward</button></h1></td><td width=\"40%\"></td></tr>\r\n";
C:\Users\Damian\Documents\Arduino\libraries\WizFiShield\HTMLPages.cpp:22:1: error: 'prog_char' does not name a type
prog_char Middle_Line[] PROGMEM = "<tr><td width= \"40%\" align=\"right\"><h1><button name=\"command\" value=\"LEFT_CMD\">LEFT</button></h1></td>";
C:\Users\Damian\Documents\Arduino\libraries\WizFiShield\HTMLPages.cpp:23:1: error: 'prog_char' does not name a type
prog_char Middle_Line_cont[] PROGMEM = "<td width=\"20%\"></td><td width= \"40%\" align=\"left\"><h1><button name=\"command\" value=\"RIGHT_CMD\">";
C:\Users\Damian\Documents\Arduino\libraries\WizFiShield\HTMLPages.cpp:24:1: error: 'prog_char' does not name a type
prog_char Middle_Line_cont2[] PROGMEM = "RIGHT</button></h1></td></tr>\r\n";
C:\Users\Damian\Documents\Arduino\libraries\WizFiShield\HTMLPages.cpp:25:1: error: 'prog_char' does not name a type
prog_char Page1_Line9[] PROGMEM = "<tr><td width=\"40%\"></td><td width= \"20%\" bgcolor=\"#c3c3c3\" align=\"center\"><h1><button name=\"command\" ";
C:\Users\Damian\Documents\Arduino\libraries\WizFiShield\HTMLPages.cpp:26:1: error: 'prog_char' does not name a type
prog_char Page1_Line9_cont[] PROGMEM = "value=\"BW_CMD\">backward</button></h1></td><td width=\"40%\"></td></tr></table>\r\n";
C:\Users\Damian\Documents\Arduino\libraries\WizFiShield\HTMLPages.cpp:27:1: error: 'prog_char' does not name a type
prog_char Page1_Line10[] PROGMEM = "</form>\r\n";
C:\Users\Damian\Documents\Arduino\libraries\WizFiShield\HTMLPages.cpp:28:1: error: 'prog_char' does not name a type
prog_char Page1_Line11[] PROGMEM = "</body>\r\n";
C:\Users\Damian\Documents\Arduino\libraries\WizFiShield\HTMLPages.cpp:29:1: error: 'prog_char' does not name a type
prog_char Page1_Line12[] PROGMEM = "<table width=\"100%\"><tr><td colspan=3 align=\"center\"><h1>Press button you want. Battery is low.</h1></td></tr><tr>";
C:\Users\Damian\Documents\Arduino\libraries\WizFiShield\HTMLPages.cpp:30:1: error: 'prog_char' does not name a type
prog_char Page1_Line13[] PROGMEM = "<table width=\"100%\"><tr><td colspan=3 align=\"center\"><h1>Alert! Battery is too low.</h1></td></tr></table>\r\n";
C:\Users\Damian\Documents\Arduino\libraries\WizFiShield\HTMLPages.cpp:31:1: error: 'prog_char' does not name a type
prog_char Html_end[] PROGMEM = "</html>\r\n"; // "String 0" etc are strings to store - change to suit.
C:\Users\Damian\Documents\Arduino\libraries\WizFiShield\HTMLPages.cpp:34:32: error: variable 'HTML_table' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
PROGMEM const char *HTML_table[] =
C:\Users\Damian\Documents\Arduino\libraries\WizFiShield\HTMLPages.cpp:36:2: error: 'Protocol_Msg' was not declared in this scope
Protocol_Msg,
C:\Users\Damian\Documents\Arduino\libraries\WizFiShield\HTMLPages.cpp:37:2: error: 'Content_Msg' was not declared in this scope
Content_Msg,
C:\Users\Damian\Documents\Arduino\libraries\WizFiShield\HTMLPages.cpp:38:2: error: 'new_Line' was not declared in this scope
new_Line, // 0
C:\Users\Damian\Documents\Arduino\libraries\WizFiShield\HTMLPages.cpp:39:2: error: 'Page1_Line7' was not declared in this scope
Page1_Line7, // 6
C:\Users\Damian\Documents\Arduino\libraries\WizFiShield\HTMLPages.cpp:40:2: error: 'Page1_Line8' was not declared in this scope
Page1_Line8, // 7
C:\Users\Damian\Documents\Arduino\libraries\WizFiShield\HTMLPages.cpp:41:2: error: 'Page1_Line8_cont' was not declared in this scope
Page1_Line8_cont,
C:\Users\Damian\Documents\Arduino\libraries\WizFiShield\HTMLPages.cpp:42:2: error: 'Page1_Line8_cont2' was not declared in this scope
Page1_Line8_cont2,
C:\Users\Damian\Documents\Arduino\libraries\WizFiShield\HTMLPages.cpp:43:2: error: 'Middle_Line' was not declared in this scope
Middle_Line,
C:\Users\Damian\Documents\Arduino\libraries\WizFiShield\HTMLPages.cpp:44:2: error: 'Middle_Line_cont' was not declared in this scope
Middle_Line_cont,
C:\Users\Damian\Documents\Arduino\libraries\WizFiShield\HTMLPages.cpp:45:2: error: 'Middle_Line_cont2' was not declared in this scope
Middle_Line_cont2,
C:\Users\Damian\Documents\Arduino\libraries\WizFiShield\HTMLPages.cpp:46:2: error: 'Page1_Line9' was not declared in this scope
Page1_Line9, // 8
C:\Users\Damian\Documents\Arduino\libraries\WizFiShield\HTMLPages.cpp:47:2: error: 'Page1_Line9_cont' was not declared in this scope
Page1_Line9_cont, // 8
C:\Users\Damian\Documents\Arduino\libraries\WizFiShield\HTMLPages.cpp:48:2: error: 'Page1_Line10' was not declared in this scope
Page1_Line10 // 9
C:\Users\Damian\Documents\Arduino\libraries\WizFiShield\HTMLPages.cpp:51:33: error: variable 'HTML_table2' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
PROGMEM const char *HTML_table2[] =
C:\Users\Damian\Documents\Arduino\libraries\WizFiShield\HTMLPages.cpp:53:2: error: 'Protocol_Msg' was not declared in this scope
Protocol_Msg,
C:\Users\Damian\Documents\Arduino\libraries\WizFiShield\HTMLPages.cpp:54:2: error: 'Content_Msg' was not declared in this scope
Content_Msg,
C:\Users\Damian\Documents\Arduino\libraries\WizFiShield\HTMLPages.cpp:55:2: error: 'new_Line' was not declared in this scope
new_Line, // 0
C:\Users\Damian\Documents\Arduino\libraries\WizFiShield\HTMLPages.cpp:56:2: error: 'Page1_Line7' was not declared in this scope
Page1_Line7, // 6
C:\Users\Damian\Documents\Arduino\libraries\WizFiShield\HTMLPages.cpp:57:2: error: 'Page1_Line12' was not declared in this scope
Page1_Line12, // 7
C:\Users\Damian\Documents\Arduino\libraries\WizFiShield\HTMLPages.cpp:58:2: error: 'Page1_Line8_cont' was not declared in this scope
Page1_Line8_cont,
C:\Users\Damian\Documents\Arduino\libraries\WizFiShield\HTMLPages.cpp:59:2: error: 'Page1_Line8_cont2' was not declared in this scope
Page1_Line8_cont2,
C:\Users\Damian\Documents\Arduino\libraries\WizFiShield\HTMLPages.cpp:60:2: error: 'Middle_Line' was not declared in this scope
Middle_Line,
C:\Users\Damian\Documents\Arduino\libraries\WizFiShield\HTMLPages.cpp:61:2: error: 'Middle_Line_cont' was not declared in this scope
Middle_Line_cont,
C:\Users\Damian\Documents\Arduino\libraries\WizFiShield\HTMLPages.cpp:62:2: error: 'Middle_Line_cont2' was not declared in this scope
Middle_Line_cont2,
C:\Users\Damian\Documents\Arduino\libraries\WizFiShield\HTMLPages.cpp:63:2: error: 'Page1_Line9' was not declared in this scope
Page1_Line9, // 8
C:\Users\Damian\Documents\Arduino\libraries\WizFiShield\HTMLPages.cpp:64:2: error: 'Page1_Line9_cont' was not declared in this scope
C:\Users\Damian\Documents\Arduino\libraries\WizFiShield\HTMLPages.cpp:65:2: error: 'Page1_Line10' was not declared in this scope
Page1_Line10 // 9
C:\Users\Damian\Documents\Arduino\libraries\WizFiShield\HTMLPages.cpp:68:33: error: variable 'HTML_table3' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
PROGMEM const char *HTML_table3[] =
C:\Users\Damian\Documents\Arduino\libraries\WizFiShield\HTMLPages.cpp:70:2: error: 'Protocol_Msg' was not declared in this scope
Protocol_Msg,
C:\Users\Damian\Documents\Arduino\libraries\WizFiShield\HTMLPages.cpp:71:2: error: 'Content_Msg' was not declared in this scope
Content_Msg,
C:\Users\Damian\Documents\Arduino\libraries\WizFiShield\HTMLPages.cpp:72:2: error: 'new_Line' was not declared in this scope
new_Line, // 0
C:\Users\Damian\Documents\Arduino\libraries\WizFiShield\HTMLPages.cpp:73:2: error: 'Page1_Line7' was not declared in this scope
Page1_Line7, // 6
C:\Users\Damian\Documents\Arduino\libraries\WizFiShield\HTMLPages.cpp:74:2: error: 'Page1_Line13' was not declared in this scope
Page1_Line13, // 7
C:\Users\Damian\Documents\Arduino\libraries\WizFiShield\HTMLPages.cpp:75:2: error: 'Page1_Line10' was not declared in this scope
Page1_Line10 // 9
Error compiling.
I am working in Win8, but never had a problem until now. I have a feeling that this code is simply outdated, but then so would the literature about it.
Thanks for your help.
