On my local computer on a university network (with Enterprise encryption) I am running a server in which I am trying to access using the WizFi210 w/ Arduino. I have a couple of concerns. I am using the following board:
[url]WiFi Shield V2.2 for Arduino (802.11 b/g/n) -DFRobot
Initially I was using an Arduino Due and I receiving an [ERROR] and I was not able to supply AT commands. I switched over to the Uno and it works just fine. Does the WizFi not like 3V3 logic? I prefer to use the Due.
With the Uno, I am able to communicate with it via serial. It takes a couple of “AT” commands but it works eventually. For example:
[code]at
[ERROR: INVALID INPUT]
at
[OK]
at
[OK]
at
[OK]
[/code]
However I cannot use the SmartScript (1.1.1.0_W(2)). I am getting Serial Command Error (see attached).
- If it isn’t obvious, I am a newbie with networking and such. If there are some resources (other than the datasheet) to help me connect to the university network. I would appreciate it greatly.
