HaXeR
April 16, 2014, 11:21am
1
Hello everyone ,
I am computer engineer student.I have a graduation project.This project include server app , client app , mobile app.Every app is ok but wizfi210 shield that problem.
I have problem with wizfi wifi shield v1.4
(elecfreaks.com/wiki/index.ph … eld_-_EiFi )
Is there anybody use this module with arduino ?
How should I about this problem ?
Emrah ESEN
kaizen
April 17, 2014, 4:48am
2
Hi
I can connect to your URL. Your URL seems to be wrong. ([url]http://www.elecfreaks.com/wiki/index.php?title=Wifi_Shield_-_EiFi[/url] )
So I don’t know What problem do you have.
HaXeR
April 25, 2014, 12:04pm
3
Hi ,
My problem is my arduino and eifi wifi shield(wizfi210) not communicate each other.I try own page code (elecfreaks.com/wiki/index.ph … eld_-_EiFi ) and not working.
it continues …
I have tried :
wifi shield pin DOUT-D2 , DIN-D3. arduino code tx-pin 2 rx-pin 3 , use software serial lib.
[code]#include <SoftwareSerial.h>
#define rxPin 2
#define txPin 3
SoftwareSerial mySerial(rxPin, txPin);
void setup()
pinMode(rxPin, INPUT);
pinMode(txPin, OUTPUT);
mySerial.begin(9600); // setting baud to 9600
Serial.begin(9600);
void loop()
mySerial.write(“AT\r\n”);
char rcv;
if(mySerial.available())
rcv = mySerial.read();
Serial.print(rcv);
delay(1000);
}[/code]
I use this code result " ÿ " char . What does it mean ?
Where is the problem ?
yodaar
September 1, 2014, 12:47am
4
Did you get the answer? I have the same problem, thank you!
kaizen
September 1, 2014, 11:25pm
5
Hi
I am sorry for late reply.
I think it is problem in order to baud rate setting of WizFi210.
Frankly speaking, This shield and library is not made by Wiznet.
So I recommend you to ask to ELEC Freaks. Maybe there give more correct answer to you due to make library and shield by them.
Did you solve this problem? I have a same situation…
I could’nt find any information .
There is no community to elecfreak.
I think wifi module is not connected for some reasons.
