i have purchased Wiz107SR a month ago
i connected it to the PC through Hub and did its network configuration through configuration tool , IP , GW , DNS , also updated firmware to 4.06 also performed HW_triger and rest and send the software code 2b 2b 2b to start ATCommand with debug message :enabled, everything seems to be great
as showan in the screenshots
but when sending any command on hercules it respond with the debug message only … no response to the command itself
what could be the problem ?
Hello Edward. If we want change ip address and transmit it in hex serially. So for LI192.168\r\n to transmit in hex is 4C49$31$39$32$2E$31$36$38$0d$0a ?
Hi… normally I am working with Atmel Xmega controllers, but as soon as i discovered the ESP32 I fell in love with it !| . So here I am, trying to understand FreeRtos and the ESP-IDF API. After reading the FreeRtos Tutorial, I am currently trying to get the hardware timers to work. At the moment everything works fine, as long as I am using 1 Timer out of 1 group. When I try to use both timers, some weird things are happening (stuck in Interrupt?)
