I have two Wiznet S2E modules, one server and the other one is client. There are terminal windows on the serial ends of these two S2E modules.
For Baudrate of 115200 the modules transmit data without any errors.
But at Baudrate beyond that, for eg. 230400 and above, there are errors during transmission.
Is 115200 the max baudrate the WIZ750SR-110 serial interface can run on?
Kindly let me know if there is a solution to this. Thank you.
I had just one doubt regarding the data transfer rate:
Is my Ethernet packet generation rate same as my serial input rate or are they different?
Is the data transfer rate same when I receive Internet packets on the other end and convert it back to serial? (I mean will the transmission rate be same as the reception rate)
Note: I am using two Wiz750sr-110 to transfer data.
WIZ750SR-110 RS232C 제품을 구매 하였습니다.
Seiral comamds mode 에서 2B 2B 2B 가 무슨 의미 인가요 Ethehent에서 GPIO를 제어 하고 싶는땐
어떻게 하면 되나요 명령어를 입력을 해도 응답이 오지 않습니다.
어떤 모드로 세팅을 해나요?
