I need this to setup as a client on an existing wifi network. The configuration on the webpage all seems to be designed to operate in bridge mode. Is there a guide on how to plug in the ssid and other parameters of the existing wifi I want it to connect to?
As written in WIZ6000 web-page, WIZ6000 is made of WIZ610wi.
So, you had better refer to the below link.
There may be some materials which will be helpful for you.
