I quote a part of code from the socket.cpp file of Arduino ethernet library.
The entire code is:
#include “w5100.h”
#include “socket.h”
static uint16_t local_port;
@brief This Socket function initialize the channel in perticular mode, and set the port and wait for W5100 done it.
@return 1 for success else 0.
uint8_t socket(SOCKET s, uint8_t protocol, uint16_t port, uint8_t flag)
if ((protocol == SnMR::TCP) || (protocol == SnMR::UDP) || (protocol == SnMR::IPRAW) || (protocol == SnMR::MACRAW) || (protocol == SnMR::PPPOE))
close(s);
W5100.writeSnMR(s, protocol | flag);
if (port != 0) {
W5100.writeSnPORT(s, port);
else {
local_port++; // if don’t set the source port, set local_port number.
W5100.writeSnPORT(s, local_port);
W5100.execCmdSn(s, Sock_OPEN);
return 1;
return 0;
@brief This function close the socket and parameter is “s” which represent the socket number
void close(SOCKET s)
W5100.execCmdSn(s, Sock_CLOSE);
W5100.writeSnIR(s, 0xFF);
@brief This function established the connection for the channel in passive (server) mode. This function waits for the request from the peer.
uint8_t listen(SOCKET s)
if (W5100.readSnSR(s) != SnSR::INIT)
return 0;
W5100.execCmdSn(s, Sock_LISTEN);
return 1;
// set destination IP
W5100.writeSnDIPR(s, addr);
W5100.writeSnDPORT(s, port);
W5100.execCmdSn(s, Sock_CONNECT);
return 1;
@brief This function used for disconnect the socket and parameter is “s” which represent the socket number
void disconnect(SOCKET s)
W5100.execCmdSn(s, Sock_DISCON);
@brief This function used to send the data in TCP mode
uint16_t send(SOCKET s, const uint8_t * buf, uint16_t len)
uint8_t status=0;
uint16_t ret=0;
uint16_t freesize=0;
if (len > W5100.SSIZE)
ret = W5100.SSIZE; // check size not to exceed MAX size.
else
ret = len;
// if freebuf is available, start.
do
freesize = W5100.getTXFreeSize(s);
status = W5100.readSnSR(s);
if ((status != SnSR::ESTABLISHED) && (status != SnSR::CLOSE_WAIT))
ret = 0;
break;
while (freesize < ret);
// copy data
W5100.send_data_processing(s, (uint8_t *)buf, ret);
W5100.execCmdSn(s, Sock_SEND);
/* +2008.01 bj /
while ( (W5100.readSnIR(s) & SnIR::SEND_OK) != SnIR::SEND_OK )
/ m2008.01 [bj] : reduce code /
if ( W5100.readSnSR(s) == SnSR::CLOSED )
close(s);
return 0;
/ +2008.01 bj */
W5100.writeSnIR(s, SnIR::SEND_OK);
return ret;
if ( ret > 0 )
W5100.recv_data_processing(s, buf, ret);
W5100.execCmdSn(s, Sock_RECV);
return ret;
@brief Returns the first byte in the receive queue (no checking)
@return
uint16_t peek(SOCKET s, uint8_t *buf)
W5100.recv_data_processing(s, buf, 1, 1);
return 1;
if (len > W5100.SSIZE) ret = W5100.SSIZE; // check size not to exceed MAX size.
else ret = len;
if
((addr[0] == 0x00) && (addr[1] == 0x00) && (addr[2] == 0x00) && (addr[3] == 0x00)) ||
((port == 0x00)) ||(ret == 0)
/* +2008.01 [bj] : added return value */
ret = 0;
else
// copy data
/* +2008.01 bj */
if (W5100.readSnIR(s) & SnIR::TIMEOUT)
/* +2008.01 [bj]: clear interrupt */
W5100.writeSnIR(s, (SnIR::SEND_OK | SnIR::TIMEOUT)); /* clear SEND_OK & TIMEOUT */
return 0;
/* +2008.01 bj */
return ret;
@brief This function is an application I/F function which is used to receive the data in other then
- TCP mode. This function is used to receive UDP, IP_RAW and MAC_RAW mode, and handle the header as well.
@return This function return received data size for success else -1.
uint16_t recvfrom(SOCKET s, uint8_t *buf, uint16_t len, uint8_t *addr, uint16_t *port)
uint8_t head[8];
uint16_t data_len=0;
uint16_t ptr=0;
if ( len > 0 )
ptr = W5100.readSnRX_RD(s);
switch (W5100.readSnMR(s) & 0x07)
case SnMR::UDP :
W5100.read_data(s, (uint8_t *)ptr, head, 0x08);
ptr += 8;
// read peer’s IP address, port number.
addr[0] = head[0];
addr[1] = head[1];
addr[2] = head[2];
addr[3] = head[3];
*port = head[4];
*port = (*port << 8) + head[5];
data_len = head[6];
data_len = (data_len << 8) + head[7];
W5100.read_data(s, (uint8_t *)ptr, buf, data_len); // data copy.
ptr += data_len;
W5100.writeSnRX_RD(s, ptr);
break;
case SnMR::IPRAW :
W5100.read_data(s, (uint8_t *)ptr, head, 0x06);
ptr += 6;
addr[0] = head[0];
addr[1] = head[1];
addr[2] = head[2];
addr[3] = head[3];
data_len = head[4];
data_len = (data_len << 8) + head[5];
ptr += data_len;
break;
case SnMR::MACRAW:
W5100.read_data(s,(uint8_t*)ptr,head,2);
ptr+=2;
data_len = head[0];
data_len = (data_len<<8) + head[1] - 2;
W5100.read_data(s,(uint8_t*) ptr,buf,data_len);
ptr += data_len;
break;
default :
break;
return data_len;
uint16_t igmpsend(SOCKET s, const uint8_t * buf, uint16_t len)
uint8_t status=0;
uint16_t ret=0;
else
ret = len;
if (ret == 0)
return 0;
/* in case of igmp, if send fails, then socket closed /
/ if you want change, remove this code. */
close(s);
return 0;
return ret;
uint16_t bufferData(SOCKET s, uint16_t offset, const uint8_t* buf, uint16_t len)
uint16_t ret =0;
if (len > W5100.getTXFreeSize(s))
ret = W5100.getTXFreeSize(s); // check size not to exceed MAX size.
else
ret = len;
W5100.send_data_processing_offset(s, offset, buf, ret);
return ret;
int startUDP(SOCKET s, uint8_t* addr, uint16_t port)
if
((port == 0x00))
return 0;
else
return 1;
int sendUDP(SOCKET s)
/* +2008.01 bj /
/ +2008.01 [bj]: clear interrupt */
W5100.writeSnIR(s, (SnIR::SEND_OK|SnIR::TIMEOUT));
return 0;
/* +2008.01 bj */
/* Sent ok */
return 1;
