So I have TCP connection with server but I cannot send data properly:
This is how I send data:
TX_write_pinter[0] = 0x05;
TX_write_pinter[0] = 0x00;
SpiWriteRegister(0x0000, 2, transmit_buffer, 5);
SpiWriteRegister(0x0024, 1, TX_write_pinter, 1);
SpiWriteRegister(0x0001, 1, SEND, 1); //command register receive;
first argument is address and second is block address.
third is buffer and fourth is size.
So, first Tx buffer address is gonna be 0x0000 so I do not read it
then I write data in TX buffer
then I write new data size in TX_Write_Pointer
then I do SEND command;
but when I read TX_Read_pointer it gives me back strange values like 0x3060.
While I execute this code server receives this:! image|690x351
Which is obviously nothing close that I try to send.
what could be the problem ? I think I mess up with TX_Read_Pointer.
After Send command when I read TX_Write_Pointer it gives me back correct value
