Hi everybody
I have a project which connects W5500 to microchip but some reasons I have to use a dspic30f (without support MCC in MPLAB ). I’ve already found sample code or anything else realated with my project. Unfortunately, it’s hopeless. I’m stuck in the SPI connection between W5500 and dspic30f4011. How to use those library effectively.
I’ve used MPLABxIDE with XC16 compiler
Thank you so much
just integrate Source and Header files with requirement. pass Api’s for CHip Enable-disable, and byte data read write to the respective functions and make sure DHCP and DNS timer APi are called at every one second routine. Or in the Beginning ignore DHCP and DNS use Static IP. It needs Valid MAC Address to be correct.
Dear Vpan
Thank you for replying to me. I’m a new one in SPI protocol and when I’ve tried to make a new program, the conflict between w5500’s library and microchip’s library have occurred. With your advices, I think this problem is about the address, sorry for my slow on the uptake but can you explain more detail about it for me. I don’t know where I have to begin at…
This is my program and my build failed
#include <p30F4011.h>
#include “Wizchip_Conf.h”
#include “w5500.h”
#include “socket.h”
#include <spi.h>
// Socket & Port number definition
#define SOCK_ID_TCP 0
#define SOCK_ID_UDP 1
#define PORT_TCP 5000
#define PORT_UDP 10001
#define DATA_BUF_SIZE 1024
uint8_t gDATABUF[DATA_BUF_SIZE];
#define Wizchip_CS LATBbits.LATB2
#define Wizchip_CS_Direction TRISBbits.TRISB2
#define Wizchip_Rst LATBbits.LATB5
#define Wizchip_Rst_Direction TRISBbits.TRISB5
volatile wiz_NetInfo gWIZNETINFO =
{0x00, 0x14, 0xA3, 0x72, 0x17, 0x3f}, // Source Mac Address
{192, 168, 0, 122}, // Source IP Address
{255, 255, 254, 0}, // Subnet Mask
{192, 168, 0, 1}, // Gateway IP Address
{192, 168, 14, 99}, // DNS server IP Address
NETINFO_STATIC
volatile wiz_PhyConf phyConf =
PHY_CONFBY_HW, // PHY_CONFBY_SW
PHY_MODE_MANUAL, // PHY_MODE_AUTONEGO
PHY_SPEED_10, // PHY_SPEED_100
PHY_DUPLEX_FULL, // PHY_DUPLEX_HALF
wiz_NetInfo pnetinfo;
void InitSPI (void);
void CB_ChipSelect(void);
void CB_ChipDeselect(void);
void SPIWrite(unsigned int data);
unsigned int SPIRead();
void TCP_Server(void);
void UDP_Server(void);
static void W5500_Init(void);
void Delay_x_mS( int N_mS );
void InitSPI (void){
unsigned int SPICONValue;
unsigned int SPISTATValue;
TRISFbits.TRISF6 =0; //Output RF6/SCK1
TRISFbits.TRISF2 =1; //Input RF2/SDI1
TRISFbits.TRISF3 =0; //Output RF3/SDO1
ADPCFGbits.PCFG2 =1; //Pin RB2 analog in
LATBbits.LATB2 = 1;
TRISBbits.TRISB2 = 0; // Output RB2 (CS RB2)
SPICONValue = FRAME_ENABLE_OFF& //FRMEN: 0= Framed SPI support disabled
FRAME_SYNC_OUTPUT& //SPIIFSD: 0= Frame sync pulse output(master)
ENABLE_SDO_PIN& //DISSDO: 0= SDOx pin is controlled by the module
SPI_MODE16_OFF& //MODE16: 0= Communication is byte-wide (8 bits)
SPI_SMP_OFF& //SMP: 0= Input data sample at middle of data output time
SPI_CKE_OFF& //CKE: 0= Serial output data changes on transition from Idle clk to active clk state
SLAVE_ENABLE_OFF& //SSEN: 0= SS pin not use by module. Pin controlled by port function
CLK_POL_ACTIVE_HIGH& //CKP: 1= Idle state for clock is high level. Active state is low level
MASTER_ENABLE_ON& //MSTEN: 1= Master mode
SEC_PRESCAL_3_1& //SPRE<2:0>: Secondary Prescale 3:1
PRI_PRESCAL_1_1; //PPRE<1:0>: Primary Presacle 1:1
SPISTATValue = SPI_ENABLE& //SPIEN: 1= Enables module and configures SCKx, SDOx, SDIx and SSx as serial port pin
SPI_IDLE_CON& //SPISIDL: 0= Continue module operation in Idle mode
SPI_RX_OVFLOW_CLR; //SPIROV: 0= No overflow has occurred. Clear receive overflow bit
OpenSPI1(SPICONValue,SPISTATValue);
// brief Call back function for WIZCHIP select.
Wizchip_CS = 0;
// brief Call back function for WIZCHIP deselect.
Wizchip_CS = 1;
void SPIWrite(unsigned int data){
while(SPI1STATbits.SPITBF);
WriteSPI1(data);
// brief Callback function to read byte using SPI.
unsigned int SPIRead(){
uint8_t tmp = 0;
WriteSPI1(0);
while(!DataRdySPI1());
tmp = ReadSPI1();
return tmp;
// brief Handle TCP socket state.
int32_t ret;
uint16_t size = 0, sentsize = 0;
// Get status of socket
switch(getSn_SR(SOCK_ID_TCP))
// Connection established
case SOCK_ESTABLISHED :
// Check interrupt: connection with peer is successful
if(getSn_IR(SOCK_ID_TCP) & Sn_IR_CON)
// Clear corresponding bit
setSn_IR(SOCK_ID_TCP,Sn_IR_CON);
// Get received data size
if((size = getSn_RX_RSR(SOCK_ID_TCP)) > 0)
// Cut data to size of data buffer
if(size > DATA_BUF_SIZE)
size = DATA_BUF_SIZE;
ret = recv(SOCK_ID_TCP, gDATABUF, size);
// Check for error
if(ret <= 0)
return;
// Send echo to remote
sentsize = 0;
while(size != sentsize)
ret = send(SOCK_ID_TCP, gDATABUF + sentsize, size - sentsize);
// Check if remote close socket
if(ret < 0)
close(SOCK_ID_TCP);
return;
// Update number of sent bytes
sentsize += ret;
break;
// Socket received the disconnect-request (FIN packet) from the connected peer
case SOCK_CLOSE_WAIT :
// Disconnect socket
if((ret = disconnect(SOCK_ID_TCP)) != SOCK_OK)
return;
break;
// Socket is opened with TCP mode
case SOCK_INIT :
// Listen to connection request
if( (ret = listen(SOCK_ID_TCP)) != SOCK_OK)
return;
break;
// Socket is released
case SOCK_CLOSED:
// Open TCP socket
if((ret = socket(SOCK_ID_TCP, Sn_MR_TCP, PORT_TCP, 0x00)) != SOCK_ID_TCP)
return;
break;
default:
break;
// brief Handle UDP socket state.
int32_t ret;
uint16_t size, sentsize;
uint8_t destip[4];
uint16_t destport;
switch(getSn_SR(SOCK_ID_UDP))
// Socket is opened in UDP mode
case SOCK_UDP:
if((size = getSn_RX_RSR(SOCK_ID_UDP)) > 0)
ret = recvfrom(SOCK_ID_UDP, gDATABUF, size, destip, (uint16_t*)&destport);
// Check for error
if(ret <= 0)
return;
size = (uint16_t) ret;
sentsize = 0;
while(sentsize != size)
ret = sendto(SOCK_ID_UDP, gDATABUF + sentsize, size - sentsize, destip, destport);
if(ret < 0)
return;
sentsize += ret;
break;
// Socket is not opened
case SOCK_CLOSED:
// Open UDP socket
if((ret=socket(SOCK_ID_UDP, Sn_MR_UDP, PORT_UDP, 0x00)) != SOCK_ID_UDP)
return;
break;
default :
break;
// brief Initialize modules
// Set Tx and Rx buffer size to 2KB
uint8_t buffsize[8] = { 2, 2, 2, 2, 2, 2, 2, 2 };
Wizchip_Rst_Direction = 0; // Set Rst pin to be output
Wizchip_CS_Direction = 0; // Set CS pin to be output
CB_ChipDeselect(); // Deselect module
// Reset module
Wizchip_Rst = 0;
Delay_x_mS(1);
Wizchip_Rst = 1;
Delay_x_mS(1);
// SPI1_Init_Advanced(_SPI_MASTER_OSC_DIV4, _SPI_DATA_SAMPLE_MIDDLE, _SPI_CLK_IDLE_LOW, _SPI_LOW_2_HIGH);
// Wizchip initialize
wizchip_init(buffsize, buffsize, 0, 0, CB_ChipSelect, CB_ChipDeselect, 0, 0, SPIRead, SPIWrite);
// Wizchip netconf
ctlnetwork(CN_SET_NETINFO, (void*) &gWIZNETINFO);
ctlwizchip(CW_SET_PHYCONF, (void*) &phyConf);
int Loop_mS,Del_1mS;
for ( Loop_mS = 0 ; Loop_mS < N_mS ; Loop_mS++ )
for (Del_1mS = 0 ; Del_1mS < 324 ; Del_1mS ++ );
int main(void)
ADPCFG = 0; // Set PORT B as digital
InitSPI();
W5500_Init();
wizchip_getnetinfo(&pnetinfo);
while(1)
// TCP Server
TCP_Server();
// UDP Server
UDP_Server();
sorry for delay i was very sick. but; this seems like library integration error . Not something else. are u selecting write version in wiznet chip selection section.
