Is there any configuration tool for Wiz610MJ module? or any tutorial using Arduino to setup Wiz610MJ? I need to send ‘hello word’ using SPI connection from my Arduino to Wiz610MJ. Then receive it over TCP/IP by my laptop. any configuration tool?
Please refer to this document.
There is no configuration tool for the w6100.
https://wizwiki.net/wiki/lib/exe/fetch.php/osh:w6100_ethernet_shield:w6100_ethernet_shield_ug_v001e.pdf
Hi Thank you for your reply,
Actually I have followed the structure you sent, unfortunately still have problem. When I run Chat server example in Arduino IDE, Wiz610MJ module could not get correct IP ,it shows: 09:50:58.689 → Chat server address:255.255.255.255. I have checked SPI connections but still same problem
I think there is a problem with your SPI.
Please tell me the hardware environment and Arduino Code.
