Hi Guys,
I am trying to run WebServer example on Arduino Pro Micro (bit.ly/1iEC9R6).
Unfortunately, there is no SS pin on Pro Micro, so I’ve changed the main Arduino Ethernet library header file (/usr/share/arduino/libraries/Ethernet/utility/w5100.h, line 334) and redefine the SS pin as follows:
#elif defined(__AVR_ATmega32U4__)
//inline static void initSS() { DDRB |= _BV(6); };
//inline static void setSS() { PORTB &= ~_BV(6); };
//inline static void resetSS() { PORTB |= _BV(6); };
inline static void initSS() { pinMode(PRO_MICRO_SS, OUTPUT); \
digitalWrite(PRO_MICRO_SS, HIGH); };
inline static void setSS() { digitalWrite(PRO_MICRO_SS, LOW); };
inline static void resetSS() { digitalWrite(PRO_MICRO_SS, HIGH); };
and using pin 10 on Pro Micro as Slave Select pin:
#define PRO_MICRO_SS 10
Unfortunately, it is not working.
The printed IP address over serial port is 0.116.116.116
Any idea what is the problem?
P.S:
I’m using two AAA batteries to power up WIZ550io separately. Attached pins are:
Pro Micro → WIZ550io
10 → SS (J1 - pin 6)
16 → MOSI (J1 - pin 3)
14 → MISO (J1 - pin 4)
15 → SCLK (J1 - pin 5)
The RSTn pin (J2- pin 3) is not connected.
