hello, I’m having difficulty with the W5100S chip, I’m using it in conjunction with the Arduino libraries but I can’t ping the W5100S, however when I use a shield with the W5100 everything works normally. I would like to know if there would be any special configuration in the arduino library that I can prevent from working?
I am available to send any support material that is necessary.
Facing almost same problem. Have you solved this issue? How?
W5100S net info set issue - TCP/IP Chip - WIZnet Developer Forum
Can you please share is possible?
Thanks
